Mitäs asiantuntijat ovat mieltä kyseisen firman turbosarjoista.
Lähinnä tuo Phase1 Garrett- sarja kiinnostaisi. Tässä Babelfish-käännös:
240-270 HP
The loader can furnish up to 280 HP and fits directly on the Originalkr?er as well as to the breech piece.
- to turbochargers save GT25/8R-KKK
- Wastegate internally
- Pop off piston valve Baileys o. Forge
- water pipeline set
-?leitungsset
- K&N air cleaner
- seals
- screw connections
- clips
- EPROM 1,8T phase 1 save
- fitting instruction
optionally:
- Turbokr?er f?Garrett GT25/8R-KKK with vergr?rten tubing cross sections and better Rohrf?ung than the Serienkr?er
- breech piece 76mm
- Einspritzd?n 380ccm
- high-grade steel Rennkat 100 cells
- high-grade steel exhaust system 63,5mm
- load air system small Forge
Hintaa tällä 2095 Euroa
Tässä linkki sivulle: http://www.ls-cartec.de/18ta4.htm
240-270 HP
-?leitungsset
- K&N air cleaner
- seals
- screw connections
- clips
optionally:
- breech piece 76mm
