Nettiauto yms -thread
  • http://www.nettiauto.com/audi/a4/11852945
    Tarkasti pidetty DTM tarjolla
    • Tuon kun ruostesuojaisi kunnolla (jos ei jo ole) ja jättää talveksi talliin niin voisi ehkä nostaa hintaansa jossain vaiheessa. Nyt on kyllä yhtä utopistinen pyynti kuin vaikkapa 535d e6x lci bemareissa, vai onko se vaan ettei köyhä ymmärrä mikä niissä maksaa. Tai sitten näissäkin tapauksissa vaimo käskenyt laittaa myyntiin ja latastaan semmonen hinta ettei varmasti mene kaupaksi.
      Viimeksi muokannut vV8m5; 7.1.2021, 21:42.
      • https://suchen.mobile.de/fahrzeuge/d...l?id=313674768
        In June 2005,[5] Audi announced a limited edition run of 250 special edition S4 saloon cars, celebrating 25 years of quattro four wheel drive. This exclusive model was called the Audi S4 25quattro. Available only in the United States, the exterior has unique front and rear bumpers, a carbon fibre boot lip spoiler and lower front splitter, a rear functional red tow hook, and a high gloss Phantom Black painted grille with the "quattro" emblem. 15-spoke DTM alloy wheels, along with optional dealer-fitted 'Audi four-rings' decals for the front doors complete the exterior makeover. Black and grey contrasting interior leathers, along with "quattro" embossed into the Recaro seats, together with a "1 of 250" exclusive quattro gear shift knob for the manual-only gearbox define the interior changes and act as a subtle reminder of the exclusivity that the limited numbers command.
        On the mechanical side, the S4 25quattro was the second Audi, after the B7 RS4 to be fitted with the latest Torsen T-3 asymmetric ATB centre differential for its quattro permanent four-wheel drive system. Under normal grip conditions, this is set with a default rearwards torque distribution bias of 40:60 front to rear, and a maximum of 100% torque can automatically be apportioned to the rear axle (and up to 80% to the front) as conditions warrant. The final drive ratios are 3.889.
        • Harmi kun on tomaatti. Tuo linkittämäsi dtm S4 ei taida olla 25jahre erikoismalli.
          Recarohan niissä lukee.
          • Jaa jaa, pitäiskö tollasen aidon 25 jahre olla sitten myös manuaali.
            • Joo, näyttäs olevan ainoastaan avus silverinä ja manuaalina se 25th jenkkiedition. Ja pyöreät putkenpäät vs. ovaalit DTMssä.
              Actually S4 DTM and 25th Anniversary edition is different.
              25th Anniversary Edition is only for 2006 model car and there are only 250 of them. It only comes with Avus Silver color with multi-spoke DTM style rims. It has carbon fiber lip and trunk spoiler. Only available in Manual gearbox.
              Also, it has big round shape exhaust tip.
              S4 DTM is refered to be S4 with exterior sport package from quattro GmbH which looks pretty same with 25th S4.
              It has same carbon fiber spoiler but has quad tip on exhaust like regular S4.
              Simply DTM is exterior package that people refer to.
              https://www.audiworld.com/forums/s4-...4-dtm-2664822/
              https://cartype.com/pages/609/audi_s4_25quattro__2005
              Viimeksi muokannut vV8m5; 7.1.2021, 22:34.
              • Alkuperäinen kirjoittaja lateski Näytä viesti
                Saako tähän foorumille semmonen huutonauruhymiön, kokeillaanpa: xxx
                <edit: ei näköjään näytä vaikka kirjoitustilassa se näkyy. ilmoitusteksti on ihan asiallinen, mutta hinnassa uuraisten keisarin tarjous, puolet, olis kerranki lähellä>
                • 100% samaa mieltä. Tuota saakin myydä tovin ennen kuin saa myytyä. Ehkä joku poloinen joka ei tiedä Audeista mitään voi tuonkin maksaa kun luulee todella harvinaiseksi malliksi. Tuota kun tarjoaa vaihdossa autoliikkeeseen niin voi olla aika karu pudotus maanpinnalle.
                  Viimeksi muokannut okkim; 8.1.2021, 22:31. Perustelu: Tarpeeton lainaus poistettu.
                  • Hyvän alle 200 tkm ajetun BUL-koneisen B7:n hyvitykset autoliikkeissä 8000-8500 € luokkaa, myyntihinnat noin 10000 €, joilla myös todistetusti menevät kaupaksi. Ehkä DTM:stä hiukan enemmän saattaisi saada kuin tavan BUL-koneisesta B7:sta, mutta OK-kuntoisten B6/7 S4:n hinnat jo sitä tasoa, että hankala kuvitella 220 hevosvoimaisesti neloskoneisesta autosta erityisen kovia hintoja saisi.
                    Myönnettäköön, että joidenkin B7:n hinnat on varsin kovia autojen ikä huomioiden.
                    Viimeksi muokannut Kraftwerk; 8.1.2021, 22:50.
                      Niin, a4 se vaan on kuitenkin vaikka kuinka voissa paistais.
                      • Ihan soppelin hintainen bensakoneinen quufemma.
                        www.nettiauto.com/11858403
                        • https://www.nettiauto.com/audi/a6/11844675
                          Klubin kilpitaustat löytyy, joten täältä varmaan löytyy tietoakin autosta? Kiinnostaisi historia ja minkälainen kunto autolla on.
                            Jos en väärin kilpeä muista, niin saattas olla APR softattu ja meillä ( JT-Carfix) huollettu aiemmin. En ole varma onko mennyt samalta omistajalta tuonne.
                            • Pitääpä ottaa huomenna puhelu liikkeeseen ja kysellä mitä he tietävät.
                                Sieltä tuskin vastauksia tulee. Huoltokirjasta näkee onko meidän leimoja. Jos on sama auto niin hyvin pidetty ja huollettu laite ainakin sillä omistajalla joka meillä käytti.
                                • Tosiaan allekirjoittaneen vanhasta autosta kyse. JT-carfixillä APR-softattu ja vuosi sitten vaihdoin tuoreempaaan ja tällöin kaikki toimi ja kukkui ok.
                                  • Tuosta uhkapelejä harrastavalle: https://huutokaupat.com/2377746/ulos...ottovuosi-2009
                                    • Ei edes uhkapelaaja ole tyhmä, vain huutokaupan huutaja voi yltää moisiin suorituksiin eli tarjoamaan jo 5600e tästä. Hui kamala. Olisko siellä vielä jemmassa istuintaskussa esim. pyykkipulveria jota auton alunperin menettänyt on vailla :)
                                      • https://www.nettiauto.com/audi/s3/11862658
                                        Herran autojobbaus jatkuu
                                        • Alkuperäinen kirjoittaja saska Näytä viesti
                                          Saatan laitella yv:tä jos tulee jotain syvempää kysyttävää. Tähän asti riittää kyllä tänä tieto ettei mitään pommia mene ostamaan.
                                          • Vaikka kilometrejä on vähän ja jotkut povaavat B7 Rs4 hintojen nousevan niin en ihan lähtisi maksamaan 70k€
                                            Vai mahtaako hinta korjaantua kun ilmoitusta täydennetään.
                                            https://www.nettiauto.com/audi/rs4/11866484
                                            Viimeksi muokannut Makrilli; 13.1.2021, 12:58.
                                            • Samaa katselin että aika rohkea pyynti on lätkäisty.
                                              • Punaista RS4ää ei Jose yritä Suomessa enää myydäkään (puolet halvempi musta farkku kyllä on nettiautossa), kun pyynti on mitä on. Tosin SCC:n kanssa tämän hinta on linjassaan.
                                                https://suchen.mobile.de/fahrzeuge/d...2-179b125a7e04
                                                Viimeksi muokannut vV8m5; 13.1.2021, 09:54.
                                                • Taitaa olla amöriikan mallia oleva A4. Ei varmastikaan kaikkia häiritse, mutta ite jättäisin jenkkimallit välistä, varsinkin tuollaiset tavismallit, mitä löytynee euromalleinakin varsin hyvin myynnistä.
                                                  • Ja lisäksi vielä voi olla hankala myydä eteenpäin sitten aikanaan tuon voimalinjan takia.
                                                    • Laitetaan tähän loppuun vielä perinteinen "jos löydät paremman, niin osta se, minäkin ostaisin".
                                                      Hyväksytyt maksutavat:
                                                      - käteinen
                                                      - nordea-nordea tilisiirto
                                                      On kyllä hupiukko kun noin hinnoitellusta vajaavetoisesta multikroonikosta tuollaisia kirjoitteleepi. Eikä hinnassakaan yhtään tinkimisvaraa vaikka vain käteiskauppa hyväksytty...
                                                      Viimeksi muokannut vV8m5; 13.1.2021, 14:06.
                                                        Enpä tiedä. Suurin osa autoilijoista ei ymmärrä yleensäkään voimalinjojen päälle yhtään mitään ja tuostakaan ei sen enempää kuin että on etuveto ja automaatti.
                                                        • Alkuperäinen kirjoittaja Makrilli Näytä viesti
                                                          Nyt oli kuvat ilmoituksessa.
                                                          • Koitin katsoa tuota Amerikkamallin rekkaria biltema-haulla etta saisin VIN-koodin, niin eipa loydy ERY-615 mitaan, olisin ihan mielenkiinnosta googlannut VIN-koodilla...
