Seat on x-tra...
Vitsejä yms.
Tahaton vitsi jos sitäkään. Naurahdin kuitenkin jyrkästi teknarin sivuilla ollutta BMW M550d xDRIVE mainosta.
Kissan kokoisilla kirjaimilla "Kolmen ahtimen valtakunta". Kannattaiskohan noiden saksalaisten nyt kuitenkaan ehdointahdoin mainita niitä kolmia ja valtakuntia samassa sloganissa.
"Kerrostalon pyykkitupa on normaalisti paikka, minne vakava rikollisuus ei yllä." Pelkäävät pesukoneita?
A useful language and technical descriptions...
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--....'
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK :
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT PLANK OF PINE 4X2:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly off in bolt holes, normally perfectly flush, thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50p part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
FUKKIT TOOL:
Any handy tool that you grab and throw across the garage while yelling 'FUKKIT' at the top of your lungs. It is also, most often, the next tool that you will need.
Mistä roudari tietää että lava on vinossa?
-Lauri Tähkän naama on suorassa
Lauri Tähkä uaz
Alkuperäinen kirjoittaja Nelioviveto Näytä viestiAihetta liipaten:
Lauri Tähkä uaz
Alkuperäinen kirjoittaja hopsis Näytä viestiTahaton vitsi jos sitäkään. Naurahdin kuitenkin jyrkästi teknarin sivuilla ollutta BMW M550d xDRIVE mainosta.
"Ajattele nyt parikymppistä ihmistä. Se jaksaa keskittyä kahteen asiaan. Jos yrittää opiskella, urheilla ja naida, niin siinä on yks liikaa." -Seppo Räty. :D
"Savolaiset ovat maailman ainoa kansa, jolla pitäisi olla vakioveikkauksessa neljä merkkiä: 1X2 ja voepihan tuo olla..."
Tuolta netin ihmeellisestä maailmasta löyty nääkin :)
Viisi saksalaiskaverusta oli päättänyt lähteä Audi Quattrolla vähän kiertelemään Eurooppaa. He ajelivat Itävallan ja Sveitsin läpi ja saapuivat Italian pohjoisrajalle. Siellä tullimies heidät pysäytti, katsoi auton ja kuskin paperit ja siirtyi tarkastelemaan matkustajia. Äkkiä hän huomasi, että kavereita on yhteensä viisi, ja ilmoitti, että koska kyseessä on Audi Quattro, saa autossa olla vain neljä henkeä. Kaverukset olivat hetken ihan äimän käkenä, ja tulivat sitten siihen tulokseen, että kyseessä on varmaankin vitsi. Tullimies pysyi kuitenkin tiukkana, ja ilmoitti, että siinä autossa vain neljä voi jatkaa matkaa Italian puolelle. Kaverukset koittivat selittää, että eihän Quattro nyt henkilömäärää tarkoita, vaan nelivetoa, mutta tullimies pysyi tiukasti kannassaan. Lopulta he eivät keksineet muuta kuin vaatia tullimiehen esimiestä paikalle selvittämään tilanne. Vastaus kuului: "Hän ei nyt pääse, tuolla on kolme kaveria Fiat Unossa".
Olikos jo seuraava täällä...?
Naiset kaverisuhteet:
Nainen viettää yönsä jossain teillä tietämättömillä ja seuraavana päivänä sanoo miehelleen olleensa ystävättärensä luona yön.
Mies soittaa vaimon 10 parhalle kaverille varmistaakseen onko näin ollut. Yksikään kavereistä ei tiedä asiasta mitään.
Miehen kaverisuhteet:
Mies viettää yönsä teillä tietämättömillä ja seuraavana päivä sanoo vaimolleen olleensa kaverinsa luona yön.
Vaimo soittaa miehen 10 parhaalle kaverille varmistaakseen asian. 8 näistä kavereista vahvistaa asian ja 2 sanoo miehen vielä nukkuvan hänen sohvalla.
Pikkupoika tarvitsi 50 euroa uuteen tietokonepeliin. Kuultuaan, että Jumala auttaa hädässä, poika kirjoitti Jumalalle kirjeen, jossa hän pyysi kaikkivaltiaaltamme 50 euroa.
Postilaitoksella ei kuitenkaan tiedetty, minne Jumalalle tarkoitetut kirjeet pitäisi lähettää, joten se lähetettiin pääministeri Jyrki Kataiselle.
Kataista pojan kirje nauratti sen verran, että hän päätti lähettää pojalle omissa nimissään kaksi kymppiä.
Muutaman päivän kuluttua Katainen sai jälleen Jumalalle suunnatun kirjeen.
Siinä luki: - Arvoisa Jumala. Kiitos rahasta. Jostain syystä olit kuitenkin lähettänyt sen Kokoomuksen kautta ja kuten tavallista, he olivat vetäneet välistä 60 prosenttia
Taitaa mennä tähä kategoriaan, ei nää oo vasta ku 10 vuotta myöhäs :D
http://www.iltasanomat.fi/autot/volv...470801404.html
Kolme miestä oli telttaretkellä. Aamulla sitten yksi mies alkoi kertomaan kuinka hän oli nussinut koko yön aivan helvetin upeaa naista. Toinen mies hämmästyneenä, että kuinka sattuikin, kun hänkin näki ihan samanlaisen unen. Näiden kahden välissä nukkunut kolmas mies kertoi happamana, kuinka hän oli hiihtänyt koko vitun yön Salpausselän hiihtokisoissa ja juuri kun maaliviiva häämötti, niin sauvat suli käsiin.
