Tämmöinen pisti silmää, että olisi mahdollista saada tussahdukset, ilman että katit palais ja seokset menis sekasin.
Millä periaatteella toimii, ei mene järkee jos ilmaan tulee jostain pihalle, niin ainahan siinä on virhe ilmamäärämittarin mittaamaan ilmaan verrattuna.
Suora lainaus:
Suora lainaus:
The Hybrid Valve (GFBBOV3) has been specifically developed for air flow metered cars where some venting back to turbo is beneficial, so as not to confuse the computer into providing more fuel than necessary, and in most cases, stopping the backfires caused by excess unburnt fuel igniting in your exhaust.
In most cases totally eliminates nasty little backfires on air-flow metered cars, but will still give the great sound that you want.
Manufactured from the highest grade 6061-T6 aluminium billet, on the latest Multi-Axis CNC machines, the GFB Blow Off Valves are sure to exceed your expectations of quality, style and performance.
Comes with GFB Multifit Adaptor that attaches to 35mm ID rubber hose or with grub screws to a 25mm OD pipe on the inlet side. Comes with adapter to fit 30mm ID rubber hose on the plumb back side.
If this doesn't suit your vehicle, fittings are also available to suit 20, 25, or 30mm ID rubber hose on the inlet side, and 20 or 25mm on the plumb back side.
Special Offer - Free Hose Adaptors! When placing your order, use the comments section to let us know what size you need or what vehicle you have, and your GFB BOV will come with the proper inlet and plumb back hose adaptors factory installed.
