s4 b5 2.7 ahtopaine
  • s4 b5 2.7 ahtopaine
    Tuntuu oudolta tuo ahtopaine käytös ja näyttäs että paras ahto olis 3400rpm ja ahdon pitäs olla vähintään 1,1bar nyt jää 0,9bar.
    Osaisko tuosta kattua että mikä mättää.
    ,Group A:,'002,,,,Group B:,'115,,,,Group C:,'114
    ,,Engine speed,Engine load,Injection time,Mass air flow,
    ,Engine speed,Engine load,Spec'd Boost,Actual Boost,,Spec'd load,Corrected load,Engine
    load,Wastegate valve
    ,TIME,,,2-5/1.6-5ms,2.8-5.6/10-15g/s,TIME,,,990-1800 mbar,<=1800 mbar,TIME, Uncorrected,,,duty cycle
    Marker,STAMP, /min,%, ms, g/s,STAMP, /min,%, mbar, mbar,STAMP,%,%,%,%
    ,110.59,1400,67.7,7.14,27.44,111.08,1480,67.7,980. 0,1020.0,110.07,126.3,170.1,67.7,0.0
    ,112.10,1680,65.4,6.80,31.86,112.60,1760,63.2,980. 0,1030.0,111.59,150.4,197.0,66.2,0.0
    ,113.61,1920,59.4,5.78,33.06,114.11,2000,57.9,980. 0,1040.0,113.09,163.2,213.4,61.7,0.0
    ,115.12,2120,54.1,5.44,33.39,115.61,2160,53.4,980. 0,1030.0,114.60,163.2,201.5,55.6,0.0
    ,116.62,2280,55.6,5.44,36.81,117.13,2360,54.1,980. 0,1050.0,116.10,163.2,201.5,57.9,0.0
    ,118.13,2480,51.9,5.44,38.06,118.64,2520,50.4,980. 0,1050.0,117.62,163.2,201.5,52.6,0.0
    ,119.64,2600,45.9,4.42,33.64,120.13,2640,43.6,980. 0,1050.0,119.13,162.4,203.0,51.1,0.0
    ,121.15,2680,42.1,4.42,33.69,121.66,2720,42.1,980. 0,1030.0,120.62,160.9,204.5,42.1,0.0
    ,122.66,2800,41.4,4.42,33.64,123.16,2800,41.4,980. 0,1030.0,122.14,160.2,206.0,41.4,0.0
    ,124.17,2840,41.4,4.42,34.61,124.67,2880,41.4,980. 0,1030.0,123.66,158.6,204.5,41.4,0.0
    ,125.68,2920,42.1,4.42,36.78,126.18,2920,41.4,980. 0,1040.0,125.16,157.1,203.0,40.6,0.0
    ,127.20,3000,41.4,4.42,36.06,127.69,3000,40.6,980. 0,1040.0,126.67,155.6,200.0,41.4,0.0
    ,128.68,3040,34.6,3.40,30.31,129.21,3040,27.8,980. 0,1030.0,128.18,154.9,198.5,41.4,0.0
    ,130.20,3000,22.6,2.38,19.92,130.70,3000,83.5,1420 .0,1010.0,129.69,154.9,198.5,23.3,0.0
    ,131.71,3440,190.2,25.50,195.50,132.21,3680,178.9, 1990.0,1990.0,131.20,154.1,197.0,139.8,52.2
    ,133.22,4200,169.9,25.50,209.11,133.73,4480,168.4, 1920.0,1910.0,132.71,146.6,186.6,172.2,68.2
    ,134.79,4920,159.4,24.82,229.03,135.22,5120,155.6, 1870.0,1830.0,134.28,142.9,182.1,164.7,68.6
    ,136.27,5560,151.1,24.82,245.11,136.67,5720,147.4, 1790.0,1780.0,135.73,139.1,176.1,151.1,71.0
    ,137.63,6040,139.8,21.42,245.31,137.99,6160,136.8, 1720.0,1700.0,137.14,131.6,164.2,144.4,72.5
    ,138.74,6400,133.8,20.06,248.69,139.12,6480,121.1, 1430.0,1680.0,138.36,127.1,159.7,135.3,68.6
    ,139.87,6600,88.0,9.18,168.39,140.25,6520,27.1,980 .0,1200.0,139.49,125.6,158.2,107.5,37.6
    Jos olis sen verran viitseliästä väkiä että sais nähtäville vakion tai lastutetun S4:sen 3 vaihteen login. ei kumminkaan rs4:sen ahtimilla.
    kiitos etukäteen.
    Viimeksi muokannut Artsi; 8.3.2008, 20:39.
