airbagin pois kytkentä
  • airbagin pois kytkentä
    Miten helpoiten onnistuu vänkärin etu airbagin pois kytkentä. auto on b5 facelift. Virallisesti tai epävirallisesti
    Tälläiset ohjeet löytyy merkkiliikkeille:
    Self-diagnosis of airbag system BTU (Basic Triggering Unit) with and without side airbag
    Adaption: Activating and deactivating passenger's airbag unit (vehicles 1997 only >)
    With the function adaption the passenger airbag may be disabled and reactivated.
    Performing function "10 - Adaption"
    → Indicated on display: Rapid data transfer HELP
    Select function XX
    ‒ Press keys -0- and -5-.
    → Indicated on display: Rapid data transfer Q
    10 - Adaption
    ‒ Confirm input with Q key.
    → Indicated on display: Adaption
    Feed in channel No.
    ‒ Press keys -0- and -1-.
    → Indicated on display: Adaption Q
    Enter channel number 01
    The display will show the current status of the passenger's airbag (e.g. disabled). Channel 1 Adaption 1 ⇒
    Pass.-airbag disabled WSC 06812
    Adaption 0: Passenger's airbag active
    adaption 1: Passenger's airbag blocked
    ‒ Press ⇒key.
    Deactivating passenger's airbag
    Order a label with the registration card according to the individual components catalogue.
    → Indicated on display: Channel 0 Adaption 1
    Enter adaption value XXXXX
    ‒ Enter adaption value 00001.
    → Indicated on display: Channel 1 Adaption 0 Q
    → Indicated on display: Channel 1 Adaption 1 Q
    Store changed value?
    → Indicated on display: Channel 1 Adaption 1 ⇒
    Changed value is stored
    ‒ Press the ⇒ key to terminate the adaption procedure.
    Select function XX
    ‒ Switch ignition off.
    ‒ Unplug connectors for fault reader V.A.G 1551.
    ‒ Switch the ignition on.
    The warning lamp (K75) initially illuminates for approx. 4 seconds and then flashes for a further 12 seconds. This indicates that the passenger airbag has been disabled. Customers should be made aware of the different warning lamp signal.
    ‒ Attach sticker (passenger airbag not activated) to lid of glove compartment).
    The registration card enclosed with the sticker must be completed after deactivating the passenger side airbag unit and sent to the relevant sales centre or importer for registration. Disabling of the passenger airbag is to be confirmed by the workshop in the service schedule.
    The second registration card must be carefully retained by the customer until the front passenger's module is reactivated (Vehicle wallet).
    Activating passenger's airbag
    ‒ Press key -0- five times.
    Enter adaption value 00000
    Pass. airbag activated WSC 06812
    → Indicated on display: Channel 1 Adaption 0 ⇒
    Select function XX
    ‒ Remove label (passenger's airbag not functional) from lid of glove compartment.
    The registration card supplied to the customer must be completed after activating the passenger side airbag unit and sent to the relevant sales centre or importer for registration. Activation of the passenger airbag unit by the workshop must be confirmed in the service schedule.
      Virallisesti asentamalla alkuperäinen avain-kytkin hanskalokeroon jolloin airbagin poiskytkentä jää käyttäjän vastuulle.
        Minulla on ohjelmoitu airbag ruotsissa pois ja nyt kävin katsastamassa suomessa ton auton, niin ei puhunut setä mitään vaikka bägin valo vilkkuu hetken aikaa ku käynnistää auton.
          Osalista avaimella poiskytkettäväksi, n 430 ?, joista kallein osa sisävalo, jossa varoitusteksti että bagi on poiskytkettynä 180 ?.
          Audi A4 1995► from chassis no.: 8DXA 200 001
          Note!Refer to ETKA and check that the specified part numbers / components are suitable for installation in the vehicle in question.
          The ?X?s in the part number indicate different component or colour versions. Refer to ETKA for assignment.
          Components required
          - 4B0 919 237 (B98) Key switch
          - 107 857 113 JB Lock for key switch (order on the basis of key number and/or chassis number)
          - 8D1 857 077 Mounting bracket for key switch
          - 8D0 947 111 X XXX Interior light on models without sun roof, including ?PASSENGER AIRBAG OFF? lamp
          - 8D0 947 106 XXX Interior light on models with sun roof, including ?PASSENGER AIRBAG OFF? lamp
          Edit: Markon viestiin: Tosiaan tuossa tekstissä kerrotaan, että lamppu palaa mittaristossa 4 sec ja vilkkuu vielä 12 sek jos bagi kytketään ohjelmallisesti pois.
            Juu kyllähän tämä tästä selkis. Kiitos tiedoista!
