VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 10712
Shop #: WSC 66565
WAUZZZ4B12N008818 AUZ7Z0A1872326
7 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow
P1423 - 35-10 - - - Intermittent
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow
P1411 - 35-10 - - - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 AD
Component: A6-Klimavollautomat 0104
Coding: 00000
Shop #: WSC 02325
3 Faults Found:
01809 - Actuating Motor for Temperature Flap: Left (V158)
41-10 - Blocked or No Voltage - Intermittent
01592 - Air Quality Sensor (G238)
37-00 - Faulty
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Address 16 -------------------------------------------------------
Controller: 4B0 907 487 C
Component: Lenkradelektronik D01
Coding: 01005
Shop #: WSC 02325
4 Faults Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
01304 - Radio
01302 - Control Module for Telematic (J499)
01301 - Control Module for Voice Recognition (J507)
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06731
Shop #: WSC 02325
No fault code found.
Address 45 -------------------------------------------------------
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02325
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00050
Shop #: WSC 02325
End -------------------------------------------------------
Moottorin vikakoodeista ei kannata välittää ;)
Coding: 10712
Shop #: WSC 66565
7 Faults Found:
Coding: 00000
Shop #: WSC 02325
3 Faults Found:
37-00 - Faulty
Coding: 01005
Shop #: WSC 02325
4 Faults Found:
01304 - Radio
Coding: 06731
Shop #: WSC 02325
Coding: 00102
Shop #: WSC 02325
Coding: 00050
Shop #: WSC 02325
