Soittimen kovalevyn tyhjentäminen
  • Soittimen kovalevyn tyhjentäminen
    Ostin Audin A6sen jonka soittimessa kovalevy.
    Miten sieltä poistetaan entisen omistajan biisit?
    Äkkiseltään en löytänyt - että kuinka.
    Näin Neuvovat audizinellä:
    "You go and listen to music on the juke with the Media button, then I believe it's "Setup" and scroll down a page, and choose to delete music. This will give you an option to move through folders and either select an entire folder to nuke, or you can select tracks within the folders by drilling down - these are displayed with a check box in the small square by the selections. When done, scroll all the way to the top, and keep choosing "go up" till you see the "delete selected" at the top, then it will blow away those you checked off"
      Kiitos!
      Homma onnistui.
