Rakentelin tuon OBD kaapelin ja vikakoodit näytti seuraavaa:
Autona A4 -02 1.8T.
Kaipaisin tietoja faulteista näin noviisina. Virta oli päällä, mutta autoa en käynnistänyt.
Autona A4 -02 1.8T.
Koodi:
VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 Component: 1.8L R4/5VT G 0001 Coding: 0011501 Shop #: WSC 63351 1 Fault Found: 16712 - Knock Sensor 1 (G61): Signal too High P0328 - 001 - Upper Limit Exceeded - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04275 Shop #: WSC 06435 No fault code found. Address 08 ------------------------------------------------------- Controller: 8E0 820 043 A Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 No fault code found. Address 09 ------------------------------------------------------- Controller: 8E0 907 279 E Component: int. Lastmodul NDL 0305 Coding: 00002 Shop #: WSC 63351 No fault code found. Address 15 ------------------------------------------------------- Controller: 8E0 959 655 Component: Airbag 8.4E 4001 Coding: 0010602 Shop #: WSC 63351 No fault code found. Address 16 ------------------------------------------------------- Controller: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00041 Shop #: WSC 63351 No fault code found. Address 17 ------------------------------------------------------- Controller: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D25 Coding: 00100 Shop #: WSC 00101 WAUZZZ8E72A161179 AUZ6Z0A0273830 No fault code found. Address 46 ------------------------------------------------------- Controller: 8E0 959 433 AD Component: Komfortgerát T85 0315 Coding: 06720 Shop #: WSC 63351 1 Fault Found: 01331 - Door Control Module: Driver Side (J386) 80-10 - Single-Wire Operation - Intermittent End -------------------------------------------------------
