Mitä nämä vikakoodit tarkoittavat
  • Mitä nämä vikakoodit tarkoittavat
    Rakentelin tuon OBD kaapelin ja vikakoodit näytti seuraavaa:
    Autona A4 -02 1.8T.
    Kaipaisin tietoja faulteista näin noviisina. Virta oli päällä, mutta autoa en käynnistänyt.
    Koodi:
    VAG-COM Version: Release  311.2-N
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01     -------------------------------------------------------
       Controller: 8E0 909 518
       Component: 1.8L R4/5VT     G   0001
       Coding: 0011501
       Shop #: WSC 63351
    1 Fault Found:
    16712 - Knock Sensor 1 (G61): Signal too High
                P0328 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0000 0000
    Address 03     -------------------------------------------------------
       Controller: 8E0 614 517
       Component: ABS/ESP front       1726
       Coding: 04275
       Shop #: WSC 06435
    No fault code found.
    Address 08     -------------------------------------------------------
       Controller: 8E0 820 043 A
       Component:   A4 Klimaautomat   0712
       Coding: 00000
       Shop #: WSC 63351
    Address 09     -------------------------------------------------------
       Controller: 8E0 907 279 E
       Component: int. Lastmodul  NDL 0305
       Coding: 00002
       Shop #: WSC 63351
    Address 15     -------------------------------------------------------
       Controller: 8E0 959 655
       Component: Airbag 8.4E         4001
       Coding: 0010602
       Shop #: WSC 63351
    Address 16     -------------------------------------------------------
       Controller: 8E0 953 549 L
       Component: Lenksáulenmodul     0308
       Coding: 00041
       Shop #: WSC 63351
    Address 17     -------------------------------------------------------
       Controller: 8E0 920 900 H
       Component: KOMBI+WEGFAHRS. RB4 D25
       Coding: 00100
       Shop #: WSC 00101
       WAUZZZ8E72A161179     AUZ6Z0A0273830
    Address 46     -------------------------------------------------------
       Controller: 8E0 959 433 AD
       Component: Komfortgerát T85    0315
       Coding: 06720
       Shop #: WSC 63351
    1 Fault Found:
    01331 - Door Control Module: Driver Side (J386)
                80-10 - Single-Wire Operation - Intermittent
    End   -------------------------------------------------------
    Ihan kyseisen informaation perusteella näyttäisi olevan nakutusanturi varoittanut nakuttamisesta ja kuskin oven yhteyksissä jotain häikkää (liitännät, johdot, ohjausyksikkö) eli signaali ei ole päässyt perille asti.
    Kuitenkin täytyy muistaa, että kyseiset vikailmoitukset ovat saattaneet olla ainoastaan satunnaisia vain kerran ilmenneitä vikoja tai pelkästään virheilmoituksia. Mikäli nollauksen jälkeen ilmenee uudelleen samat vikakoodit, ovat viat todennäköisiä.
