Tällaista koodia pukkaa:
Tuesday,24,February,2015,17:02:40:26988
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WV1ZZZ7HZ4H096658 License Plate:
Mileage: 240820km-149638mi Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ4H096658 Mileage: 240820km-149638miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 HW: 028 101 073 4
Component: R4 1,9L EDC 5225
Shop #: WSC 02756 785 00200
VCID: 51A34D79CB8056A9B05-515C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
Part No: 7H0 907 379 E
Component: ASR FRONT MK25 0103
Coding: 0007206
Shop #: WSC 80093 222 69422
VCID: 377713E14524E8999E1-5122
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
004 - No Signal/Communication
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Part No: 7H0 937 049 J
Component: BORDNETZ SGVER 1.0 0901
Coding: 0000037
VCID: 397315D97330FEE9685-5122
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
008 - Implausible Signal
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 3B AIRBAG VW51 0008
Coding: 13122
Shop #: WSC 02756
VCID: 2241D2B5AEA69D3159F-5122
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 850 R
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 03111
Shop #: WSC 42400
VCID: 397315D92330FEE9685-5122
WV1ZZZ7HZ4H096658 VWZ7Z0D9594918
2 Faults Found:
01176 - Key
49-00 - No Communications
Address 18: Aux. Heat Labels: 7H0-819-008.lbl
Part No: 7H0 815 071 C
Component: Standheizung 0207
Shop #: WSC 00000 000 00000
VCID: 2855C09D989A776107B-5122
3 Faults Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
01126 - Engine Speed Signal
02085 - Incorrect Control Module Installed
000 - -
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 02737
VCID: 70E5E8FD30CA7FA19FB-5122
1 Fault Found:
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: Komfortgerát 0004
Coding: 00024
Shop #: WSC 02756
VCID: 326122F5FE460DB1A9F-4B1C
No fault code found.
End-------------------------(Elapsed Time: 06:45)--------------------------
57 6E 76 77 78 7D
No Faults Found
Coding: 0007206
2 Faults Found:
Coding: 0000037
2 Faults Found:
Coding: 13122
Shop #: WSC 02756
1 Fault Found:
Coding: 03111
Shop #: WSC 42400
2 Faults Found:
01176 - Key
3 Faults Found:
00664 - Fuel gauge
000 - -
Coding: 00006
Shop #: WSC 02737
1 Fault Found:
Coding: 00024
Shop #: WSC 02756
