‒ Carefully lever rear luggage compartment light out of vehicle headliner using a screwdriver.
‒ Unscrew aerial -1-.
‒ Detach cover -2- upwards.
‒ Release securing nut -6- (3.5 Nm) and remove.
‒ Remove aerial base -5- or -9- inwards, through vehicle headliner aperture.
‒ Disconnect all connectors -3-, -4- and, if applicable, -8-. Push back locking collars -3- and -8- when dismantling.
Installing:
‒ Use screwdriver to carefully prise rear interior light out of headliner.
‒ Unscrew hexagon nut (3.5 Nm) with toothed lock washer.
‒ Unplug connectors -4-, -5- and -6-.
‒ Lift off aerial base -2-.
Installing:
‒ Install accordingly in reverse order of removal.
