  • Löytyisikö Lahdesta VCDS-mestaria joka haluasi 2007 B7 vikakoodit lukea?
    Tässä koodit, varmaa suurin osa akun tyhjenemisestä, mutta entäs puhelinboksi? Voiko tuo vika purkaa akkua?
    Monday,22,April,2013,19:41:03:20961
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E17A273595 Mileage: 206300km/128188miles
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    Shop #: WSC 06335 000 00000
    VCID: 2C5D0D078F5AD678AD4
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 29
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4222
    Hex Value: 0x0024
    Hex Value: 0x0194
    Hex Value: 0x0001
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenks·ulenmodul 0701
    Coding: 04042
    Shop #: WSC 06335
    VCID: 41834CB34BD82B106E2
    2 Faults Found:
    01301 - Control Module for Voice Recognition (J507)
    49-00 - No Communications
    01303 - Telephone Transceiver (R36)
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 932 HW: 8E0 920 932
    Component: KOMBI+WFS 4 H10 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0006018
    Shop #: WSC 31000 205 178012
    VCID: E6C93F2FD236AC283B0
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    004 - No Signal/Communication
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H73 0650
    Revision: 03S Serial number: AUZBZ7G1122985
    Coding: 0301715
    VCID: 3261137FAE7E8088E78
    3 Faults Found:
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 237
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:01:01
    Freeze Frame:
    Voltage: 13.00 V
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 237
    Time Indication: 0
    Date: 2013.04.14
    Time: 10:03:18
    Freeze Frame:
    Voltage: 13.00 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 174
    Time Indication: 0
    Date: 2006.07.18
    Time: 02:30:55
    Address 46: Central Conv. Labels: None
    Part No: 8E0 959 433 CN
    Component: Komfortger·t TA7 4236
    Coding: 07008
    Shop #: WSC 06335
    VCID: 7F070A4B7DAC9DE0586
    Subsystem 1 - Part No: 8E1959801H
    Component: T?rsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E1959802H
    Component: T?rsteuer.BF BRM 0606
    3 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    00955 - Key 1
    35-10 - - - Intermittent
    00956 - Key 2
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0301715
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 237
    Time Indication: 0
    Date: 2006.07.18
    Time: 00:01:01
    Freeze Frame:
    Voltage: 13.00 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 237
    Time Indication: 0
    Date: 2013.04.14
    Time: 10:03:18
    Freeze Frame:
    Voltage: 13.00 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 174
    Time Indication: 0
    Date: 2006.07.18
    Time: 02:30:55
    End ---------------------------------------------------------------------
    Viimeksi muokannut okkim; 27.5.2013, 10:20. Perustelu: Poistettu turhat listaukset joissa ei ollut vikaa.
    • Onko mahdollista A6 C5 saksan tuontiin saada automaattisia valoja koodattua? Googlella en löytäny mitään juttua jotta onko näin vanhoissa semmosta, vai onko se can väylän juttuja?
        Vaatii muistaakseni valokatkaisijan vaihdon.
          Ei tarvitse katkaisijaa vaihtaa, marmorilta saa retrofit-kitin, jolla onnistuu. Sisältää johtosarjan pätkän ja releen.
            Hene987, saa myös slamit.netistä:
            http://www.slamit.net/product/4365/v...kiasennussarja
            • Oisko kellään mielenkiintoa kimppatilaukseen VCDS:stä. Olen parista paikkaa kysynyt ja paras hinta olit 300€ jos saadaan 10kpl kasaan. Kyseessä ei ole se säilytyslaukullinen Pro versio vaan ihan perus versio. Jos kiinnostusta löytyy niin voisin tuonne kimppatilausosioon avata aiheen. Imoitelkaa vaikka YV:llä kiinnostuksesta.
                Ei tarvise avata. Tota on yritetty aiemminkin huonolla menestyksellä:
                http://www.audiclub.fi/audifinns/sho...755#post919755
                • Hölmöyksiä?
                  Haluaisin omaan linttaan käännettyä päälle tuon mittariston pyyhkäisyn, nyt askarruttaa:
                  Tarvitsenko oman VCDS softan vai riittääkö että liityn klubiin ja tarjoan oluet jollekkin klubilaiselle joka ruuvaa omalla softallaan tuon kuntoon?
                  Toisekseen, jos autossa olisi APRrän softaa tai muuta niin häiriintykö se tai jokin muu autossa jos mennään vielä säätämään VCDssällä päälle?
                  Joo ja saa nauraa / kuittailla, tunnen nämä laitokset todella huonosti :)
                    Ei ole olemassa tyhmä kysymys! Tyhmää vasta on jos ei kysytä ja on entistä tyhmempi sen jälkeen.
                    Et tarvitse omaa softaa, ainoastaan aito Ross-Tech piuha ja läppäri johon imuroitu se softa.
                    APR:n softa ei häirinny.
                    Jos ymmärsin oikein haluat että mittaristoa koodataan siten että virrat päälle laittaessa viisarit pyhkäisevät, menikö oikein?
                    • Jep juuri tätä yritin ilmaista, täytynee laittaa jäsenhakemus vireille :)
                        Alkuperäinen kirjoittaja amalin Näytä viesti
                        Jos sulla on longlife käytössä, niin viiva tarkottaa, että laskenta on vielä käynnissä vaatii jonkunverran ajoa.
                        Tämä pitänee paikkaansa... Nyt näyttää huoltonäyttö sitä minkä asetin.
                        En kyllä osaa sanoa kuinka kauan tai monta kilsaa meni. Nyt kun reissusta taas palasin niin näyttäs toimivan. En siis tehnyt asialle mitään.
                        Viimeksi muokannut Sabotaasi; 5.5.2013, 22:56. Perustelu: Muokkaus
                          Saakos sen ikkunoiden toiminnon koodattua pois, että kun painaa pitkää kaukosäätimestä niin ikkunat laskee tai nousee? Vissiin mikrokytkimessä vikaa kun oli nyt aamulla kaikki ikkunat alhaalla ja samaten kun lähin töistä. Ois kiva saada koodattua tuo ominaisuus pois siksi aikaa että saa korjattua.
                            Saapi.
                              Ei sattuis ulkomuistista löytymään että kuinka? :)
                              e: sulake 14 poistettu, jos ikkunat edes pysyisivät kiinni.
                              Viimeksi muokannut RistoEe; 13.5.2013, 17:04.
                              • Risto: itselläni sama vika päällä. Tein persaukisen audistin ratkaisun, ja otin kuskin oven lukkolaitteelta piuhan irti. Pelaa keskuslukko ja häly, mutta kuskin oven joutuu toki lukitsemaan avaimella lukosta erikseen.
                                  Eli siis otit koko sen liittimen irti mikä menee lukolle? Varmaan itse teen saman ennen kuin saan mikrokytkimet.
                                  Viimeksi muokannut okkim; 27.5.2013, 10:17. Perustelu: Poistettu tarpeeton lainaus.
                                  • Jep, juuri niin.
                                    Viimeksi muokannut okkim; 27.5.2013, 10:16. Perustelu: Poistettu tarpeeton lainaus.
                                      Re: VCDS (vanhalla nimellä VAG-COM)
                                      Kiitos ja kumarrus. Nyt on täällä sama viritys :)
                                      • Omassa A6 C5 TDi V6:ssa ongelmana, että tuossa ilmastoinnin econ-painikkeessa palaa jatkuvasti merkkivalo, eikä lähde pois painamalla (ei vaikka pitäisi pitkään pohjassa). Ilmastointi ei selvästikään toimi, eli kompura ei ilmeisesti lähde päälle syystä X. Epäilen kylmäaineiden vähyyttä tai anturivikaa. Noh ostin sitten tuon kaapelin ja lukaisin vikakoodit, eikä mitään mainintaa ilmastoinnin suuntaan ollut. Sivuhuomiona mainittakoot, että auto antaa kynsille usein autosta noustessa ajon jälkeen, joka saattaa selittyä noilla keskuslukon vikakoodeilla.
                                        Tässä listaus:
                                        Thursday,16,May,2013,20:35:31:32264
                                        VCDS Version: Release 11.11.3
                                        Data version: 20120401
                                        Chassis Type: 4B - Audi A6 C5
                                        Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
                                        75 76 77
                                        Address 18: Aux. Heat Labels: None
                                        Part No: 4B0 265 105 E
                                        Component: Standheizung Diesel D49ˆ
                                        Coding: 00011
                                        Shop #: WSC 02325
                                        VCID: 1E39C0A19AACF49
                                        No fault code found.
                                        Address 35: Centr. Locks Labels: 4B0-962-258.lbl
                                        Part No: 4B0 962 258 D
                                        Component: Zentralverriegelung D34
                                        Coding: 06721
                                        Shop #: WSC 02325
                                        VCID: 2A511C71D6E4089
                                        10 Faults Found:
                                        01366 - Opened Due to Crash Signal
                                        35-00 - -
                                        00947 - Trunk Lid remote Control Switch (E188)
                                        29-00 - Short to Ground
                                        00955 - Key 1
                                        09-10 - Adaptation Limit Surpassed - Intermittent
                                        00956 - Key 2
                                        01560 - Passenger Door
                                        59-00 - Can't Unlock
                                        01561 - Left Rear Door
                                        59-10 - Can't Unlock - Intermittent
                                        61-00 - Won't De-Safe
                                        61-10 - Won't De-Safe - Intermittent
                                        01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
                                        01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
                                          Et onnistu auton 12V puolelta saamaan sähköiskua, vaikka olisi "Short to Moon" :) Kangaspenkit ja sopivat vaatteet, niin johan napsii.
                                          Katso climan (08) Measuring Blockeja. Siellä pitäisi olla tieto miksi kompura ei käy.
                                          edit: Tai sitten suoraan siitä climan näytön valikon kautta kanava 52 tai 49 kertoo miksi kompura ei käy. http://www.motor-talk.de/blogs/alles...-t2136670.html
                                          Viimeksi muokannut jasso; 17.5.2013, 16:31.
                                          • Voipi olla noin tuon sähkärin kanssa :)
                                            Katsoin C-01 kohdasta, minkä pitäisi ilmeisesti olla climan vikakoodi. Tuloksena on epämääräinen 0 ja 20, mitä en osaa samasta taulukosta tulkita. Saksa taipuu huonosti ja translaten jäljiltä tuo kieli ei ole enää mitään järkevää :D
                                            Ohessa kuva, mitä näkyy näytöllä. Lisäksi mikäli tässä tilassa painan kuskin puolen lämpötilavalitsimen +-painiketta, saan jonkin epämääräisen numerorallin noihin näyttöihin, liekö siis useita vikakoodeja?
                                              Kokeilepas kanavaa 08. Jos menee tuon vanhemman climalistan mukaan, pitäisi testiajaa näytön kaikki pikselit. Pystyy arviomaan mikä versio on käytössä.
                                              • Se alkaa ensin arvosta 99 ja laskee alaspäin kunnes lopettaa arvoon 49:
                                                  Hmmm... Kai se sitten on se alempi "uudempi" lista, jos noihin on luottamista :)
                                                  Laita ECON päälle ja katso kanava 49. Pitäisi minun käsitykseni mukaan lukea 13 oikeassa näytössä. Moottori sammuksissa ja ECON pois päältä, pitäisi näyttää 16. Jos puolestaan väännät ilmeisesti puhalluksen kokonaan pois, pitäisi puolestaan lukea 14. Jos kanava 49 näyttää jotain epämääräisempää, katso kanavaa 52.
                                                  Sitten jos 49 tai 52 kanava menee yllä mainitun logiikan mukaan, seuraavaksi laita AUTO päälle ja moottori käyntiin. Sitten pitäisi näyttää miksi kompura ei kytkeydy päälle.
                                                    Löytyisikö joltain tietoa, mitä vcds kautta on kerrottava autolle, kun on asennettu irroitettava vetokoukku? Tunnistaako auto siis että kärry on kiinni ja näin ollen kytkee akustisen pysäköintitutkan pois päältä. Nyt tutka huutaa taukoamatta kärry kytkettynä peruuttaessa. Auto on siis A4 b8 avant.
                                                    • Kun koodaukset on oikein auto tunnistaa että kärry on kytketty ja kytkee tutkat päälle vai silloin kun kärry ei ole kiinni. Myös mahdollinen häly tunnistaa jos kärryn pistoke irroitetaan auton ollessa lukossa ja laukaisee hälyn. Ross-Techin wikistä löytyy nuo koodaus ohjeet mutta muistaakseni can gatewaylle on kerrottava että koukun purkki on asennettu sekä muutamassa muussa paikassa taisi olla ruksi tuota varten.
                                                      edit: tuolla ainakin 8E:lle ohjeet. Hieman erilailla kun A3:sessa näköjään.
                                                        Eipä taida tuo ohje käydä omaan kulkineeseen (b8). Sen vuoksi juuri kyselin täältä kun ei ole ross-techin wikissä ohjetta olemassa. Auto on Saksan tuonti, joten ei ollut tuota koukku valmiutta sähköjen osaltakaan. Ei siis löytynyt suoraa liitin paikkaa.
                                                          gan-gateway (19) laitetaan installation list täplä kohtaan trailer, sitten radion longcoding ja täplä kohtaan trailer . Sama mahdollisesti myös ABS:lle, vaatii security coden ensin, VCDS:n pitäisi ehdottaa koodia.
                                                          Ja koska autossa EI OLE vetokoukku valmiutta, niin saattaa moottorille tulla riittämätön jäähdytys vikakoodi.
                                                            Tänks kokeillaan noilla ohjeilla. Ei ole ainakaan vielä mitään vikakoodeja ilmaantunut vaikka kärry on perässä jo roikkunutkin.
                                                            • Ei varmasti tulekkaan mitään vikakoodia jos et ole konffannu autoon vielä vetokoukkua.
