  • Kyllä sen taitaa saada, mutta moodeja ei tietystikään voi vaihtaa "lennosta", vaan ne pitää lukita tiettyihin arvoihin (esim. Engine = dynamic). Vaihto sitten vaan koodausta vaihtamalla.
    • Oliskos tästä apua;
      http://www.vwaudiforum.co.uk/forum/s...S)-retrofitted
      I've been doing so research into installing and enabling the ADS system on my car for some time and finally did it last weekend. I had read mixed reviews as to whether or not this was worth it, on a car without the active dampers or active steering, but I can report that it does make a big difference to the standard power steering and engine throttle response. In comfort mode, the throttle seems very smooth and progressive, and the power steering light and easy to move the wheel, Auto mode is back to the factory standard, and Dynamic sharpens up everything. The best way I can describe the throttle response is like chipping the engine, you get a strong surge of power without having to depress the pedal as much and the power steering is firm and a lot more responsive and sharp.
      All in all it cot me £110 in parts from the Audi garage: switch, console surround, and some repair wires, and a 5 amp fuse. Took me about 2hrs start to finish, including the VCDS changes.
      Credit for this must got to this site for the parts list and how to guide, although the fuse box for correct installation was slightly different, and I was fitting this on a non MMI car.
      Actually all you need to do is add 3 wires, following the existing cable runs if you do a neat job, and keeping it as close to oem as possible. You will need VCDS to enable as well.
        [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
        Mikäs juttu tämä on? Onko tullut muille vastaan? Kaverin Yetistä luin koodit, ja tällainen tuli gps antennin vikakoodin yhteydessä.
        Koodina oli:
        2565 - GPS Antenna
        B1054 13 [009] - Open Circuit
          On tullut vastaan omassa B8.5:ssakin. VCDS ei näytä enää koko vikakoodisisältöä, jos ei ole uusin kaapeli. Itse törmännyt tuohon ainakin ACC:n tiimoilta.
            Näköjään tilakysymys: https://forums.ross-tech.com/showthr...gen-interfaces
              Noh nii.Tilanne on sellainen et taloudessa on kaksi samanlaista autoa A6 C5 2.4.Molemmilla ajetaan sunnilleen samanpitusta matkaa ja käyttöolosuhteet on samanlaiset.Eliminoin vielä kuljettajan vaikutuksen asiaan.Toisesta kuitenkin puuttuu alavääntö ja vie yli litran enemmän bensaa kuin toinen.Ajattelin et ilmämäärämittari tai lambda-anturit vaihtoon mut mielellään ei kokeilemalla vaan todentamalla vian ensin.Vcds on käytössä, voiko sieltä jotain arvoja seuraamalla todentaa pitäiskö vaihtaa lambdat vai ilmamäärämittari ? Päästöt on ok, vikakoodeja ei ole.
                Eipä oikein. Ei kapeakaistalambdan kanssa vcds resoluutiolla saa noin syvälle menevää vertailua tehtyä oikein kovinkaan järkevästi. Täysin kylmän tai vanhuuttaan hitaan happianturin kyllä tunnistaa. Jos tyhjäkäynnillä lambdan jännite putoaa tasaiseksi eikä sykli normaalisti mutta kierroksilla toimii, voi olla vaan vanhuuttaan hidas mutta vielä sen verran toleranssissa ettei sytytä vikakoodia.
                Sanoisin vanhan nyrkkisäännön, jos et tiedä koska ne lambdat on viimeksi vaihdettu niin vaihda, voi hyvin olla yli 20 vuotta vanhat alkuperäiset vielä. Maffithan voi kokeeksi vaihtaa päikseen toisesta autosta ensin ristiin ja seurata muuttuuko jommassa kummassa autossa kulutus.
                  Mjoo, tuota Maffin vaihtamista päikseen voisi kokeilla.Kummat noista lambdoista vaikuttaa moottorin säätöön enemmän, ennen kattia olevat vai jälkeen kattien ?
                    Putsasin kaasuläpän ja ei suostu sopeutumaan eli antaa erroria, tämä siis paskana?
                    Putsasin koska epc valoa antoi ja välillä tuuttaa varattua polkimelta eikä siis tapahdu mitään.
                    Measuring Blocks
                    Sitten 60 go
                    Switch to basic settings
                    mitään ei tapahdu. ?
                    • Saako A6:sen mittarien välissä olevaan näyttöön aktivoitu startup logo kuten S6:ssa on?
                      • Tohon mun C7 faceliftiin saa ainakin mutta jos tuohon profiilin kulkineeseen meinaat niin siitä en osaa sanoa. Se koodattiin vielä jotenkin hämärästi maaversiota vaihtamalla eli eri tavalla kuin edelliseen B8 neloseeni. Sieltä löytyy S6 ja RS6 ja jotain muutakin taisi olla. Omasta jätin orkkiksen käyttöön kun ei siellä mun makuun parempiakaan ollut.
                        • Juu, löysin niitä maaversiot ja kokeilin erilaisia, mutta ei tullut mitään logo.
                          Ajattelin että jotenkin sais aktivoitu kun kerran S6 C6:ssa on.
                          • Auto on A6 C7, jossa on alkuperäinen webasto. En pääse wcds:llä ollenkaan 18-aux/heat controlleriin. Ilmottaa "No response from controller". Kaapeli on alkuperäinen ja kaikki muu toimii hyvin. Haluaisin webaston esilämmittämään myös moottoria, joka pitäisi käydä koodaamassa tuolta. Saako n279 venttiiliä koodattua muuta kautta?
                              Se orkkis on eeberi. Saksan sivuilta käännetty ohje:
                              Activation of engine pre-heating with original heater installed
                              In the auxiliary heater control unit, you have the option of activating engine pre-heating on the Audi A6 4G and the original Eberspächer preheater. At the factory, the behavior of the auxiliary heater is such that only the interior is preheated. The N-279 valve is responsible for the interior-to-engine compartment separation. With the listed coding, the valve is deactivated, thus enabling the heating effect to be radiated into the engine circuit.
                              The following coding is to be used:
                              Select STG 18 (parking heater)
                              STG Long Coding -> Function 07
                              Byte 0
                              Disable bit 3
                              Itsellä toimi tuon ohjeen mukaan alkuperäisellä VCDS ilman ongelmia.
                              • Kaukosäädin on ainakin webaston. Onkohan sittenkin jälkiasennettu? Ongelma onkin siinä etten pääse parking heater ohjainlaitteseen ollenkaan että koodauksen voisi tehdä.
                                  Tehdaslämmittimen kaukosäätimen kuva liitteenä. Jos ei ole alkuperäinen niin eikai siihen sitten pääse VCDS:kään kiinni.
                                  • Ei ole tuon näkönen, Webaston kake on (lukee webasto). Aattelin että olisi alkuperäinen koska liekin kuva vilkkuu ilmastoinnin paneelissa kun lämmitin päällä ja mmi valikosta löytyy kohta josta lämittimen voi laittaa auto/off. Näitäkö ei ole saanut tehdas Webastolla ikinä? Auto on vm -11
                                      Alkuperäisyys selviää PR-koodeista. Mikähän on auton alustanumero tai rekisterinumero?
                                      Aina jaksaa hämmästyttää, ettei noita ole asennettu näihin vanhempiinkaan Audeihin niin, että lämppäri olisi integroitu mittariston FISiin. Ei siitä niin paljoa enempää vaivaa olisi.
                                      • Pitäis asentaa vcds uudestaan ja on tuo aito ruotsin kaapeli niin mistä löytäis ruotsin ajurit netistä, kun tietokoneessa ei ole paikkaa cd levylle.
                                          Olisiko tästä apua?
                                            https://www.auto-intern.de/media/arc...usb-driver.zip
                                              Revin A4 -05 B7:sta rikkinäiset etu sumuvalot pois. Katsoin jo etukäteen, että pitäisi saada tuo koodattua siten, ettei tule herjaa rikkinäisestä polttimosta.
                                              Pitäisi olla central electrics ja kanava 16. VCDS näyttää kuitenkin, että channel not available.
                                              Olisiko jollakin tietoa miksei onnistu tai mikä on vikana?
                                              • Onko kiinankopio rosstech vai aito kaapeli?
                                                  Aito kaapeli.
                                                  • Hei!
                                                    Hankin Amazonista VCDS-kaapelin ja latasin VCDS Liten. Valikosta löytyy A4:sia ainoastaan B6:een saakka, minulla B7. Uudempaa softaa en ole löytänyt, Aboutissa on kyllä vuosiluku 2012. Voiko tuolla softalla nähdä jotakin tietoja kulkuvälineestä?
                                                    Ja lopuksi: En missään nimessä aio koodata sillä yhtään mitään, nothing, ainoastaan tutkia mitä tietoja se näyttää. Ymmärrän tuosta systeemistä suunnilleen saman verran kuin sika auringonnoususta. ?
                                                    • Laitahan linkki ostokseesi.
                                                      edit. Eipä tarvikaan, koska Lite ei tue can-väylää ollenkaan. Tarvitset ehdan aidon johdon.
                                                      • Laitanpa linkin sittenkin :) https://www.amazon.de/gp/product/B00...?ie=UTF8&psc=1 tuollainen piuha se on. Katselin haulla "OBD software" siellä on mm. tuollainen https://www.obdautodoctor.com/ saakohan sillä mitä irti?
                                                          Osta aito!
                                                          • Osta aito.
                                                            • Kiitos vastauksista, taidanpa suosiolla luovuttaa ja jättää hommat heille joilla on hommat hanskassa. Minulla hanskat hukassa :)
                                                              Viimeksi muokannut Killeri; 31.7.2019, 20:57. Perustelu: Tarpeeton lainaus poistettu.
