sähköt akulta startille (akku penkin alla)
  • sähköt akulta startille (akku penkin alla)
    Kopioitua:
    - näyttäisi koskevan ainakin 44q tyyppiä
    VARNING: if you have the batteri back under the backsits.WHERE DOES THE MAIN cable goes??!! lOOK FOR THIS: THE MAINCABLE GOES TO THE STARTER,BUT UPON THE CHASSI,AND PASSES THE STEERINGCOLOMN. THERE I HAD THE BREAKDOWN ON THE CABLE,ONLY 4(!!!!) COPPERHEARTHREADS LEFT. i have the 44Qchassi,but others cassi may have this trouble too.
    so if you have problems with the volt,and the generator,and sometimes the starter.look behind the (right) front wheel,upon the cassi.where the MAIN cable are.it may gone bad there.
    now i have 50mm2 from the weldingtool
    Aiheeseen liittyen:
    http://www.sjmautotechnik.com/troubl.../elec.html#chg
