Asiantuntijat voisivat hiukan auttaa seuraavien vikakoodien tulkinnassa:
Eli moottorissa
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 N HW: 4F1 907 559
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 01050003190F0120
Shop #: WSC 02325 785 0020
000632 - Fuel Injector #6 (N84): Contribution/Balance Fault
P0278 - 006 - Short to Plus
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 59474 km
Time Indication: 0
Date: 2009.01.18
Time: 12:18:48
Freeze Frame:
RPM: 1184 /min
Mass Air / Rev.: 212.6 mg/str
Temperature: 90.0°C
Part Throttle
Load: 33.7 %
Speed: 5.0 km/h
000617 - Fuel Injector #3 (N32): Contribution/Balance Fault
P0269 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Mileage: 59823 km
Time Indication: 0
Date: 2009.01.29
Time: 15:01:30
Freeze Frame:
RPM: 704 /min
Mass Air / Rev.: 125.3 mg/str
Temperature: 75.0°C
Idle
Load: 20.8 %
Speed: 0.0 km/h
Sekä
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 769 A HW: 4F0 035 769 A
Component: MMI Cockpit H35 0010
Revision: C51100DE Serial number: AUZ6Z3EC4B19U1
Coding: 0504002
Shop #: WSC 02331 785 00200
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.14
Time: 13:10:51
Sekä vielä tässä
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000173689
Shop #: WSC 14500 205 68491
Part No: 4F0 915 105 C
Component: von VA0 1511300412
Coding: 344630393135313035432056413031353131333030343132
Shop #: WSC 00000 384 00290
2 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.19
Time: 17:48:02
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.19
Time: 17:57:29
Autolla on ajettu nyt 61000 km ja viat on näköjään tulleet edellisen omistajan aikana tai paremminkin autoliikkeessä koeajojen aikana. Lieneekö viat sitten enää päällä? Mitä noiden kanssa pitäisi tehdä?
Eli moottorissa
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 59474 km
Time Indication: 0
Date: 2009.01.18
Time: 12:18:48
Freeze Frame:
RPM: 1184 /min
Temperature: 90.0°C
Part Throttle
Load: 33.7 %
Speed: 5.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 12
Mileage: 59823 km
Time Indication: 0
Date: 2009.01.29
Time: 15:01:30
Freeze Frame:
RPM: 704 /min
Temperature: 75.0°C
Idle
Load: 20.8 %
Speed: 0.0 km/h
Sekä
Coding: 0504002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.14
Time: 13:10:51
Sekä vielä tässä
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.19
Time: 17:48:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 59847 km
Time Indication: 0
Date: 2009.03.19
Time: 17:57:29
