Avantin takaluukun verhouksen irroitus
    Näyttää siltä että 2001 a6 avantissani takalasin pesin vuotaa takaluukun sisään.
    Niinpä olisi tarve irroittaa takaluukun sisäverhous jotta pääsisisin tarkastamaan pesurin letkun.
    Verhouksesta löytyi kaksi ruuvia, toinen sisäpuolisen kahvan ruuvi ja toinen varoituskolmio kotelossa. Nuo ruuvit avaamalla verhouspaneeli ei kuitenkaan vielä lähde irti.
    Joten tietäisikö kukaan kuinka tuo takaluukun verhous irtoaa hajottamatta sitä?
    Kiitos
    http://www.imagestation.com/picture/...c.jpg.orig.jpg
    Tailgate trim, removing and installing
    1 - Tailgate trim (bottom section)
    Removing
    - Remove bolt -3- (1x).
    - Remove screw behind warning triangle Fig. 1 .
    - Pull bottom section of trim -1- away from tailgate slightly.
    - Using a screwdriver, release clips -6- (8x) on bottom section of trim -1-.
    - Push out light -8- from inside.
    - Disconnect connector for light -8-.
    Installing
    - Locate bottom section of trim -1- at rear window first, and clip into place.
    - Make sure that screw -3- also secures grip molding -4- (shown in inset A).
    http://www.imagestation.com/picture/...5/f4ae364f.jpg
    http://www.imagestation.com/picture/...d.jpg.orig.jpg
    Removing
    - Remove rear window wiper
    - Remove interior trim from tailgate:
    - Disconnect harness connector - 7 -.
    - Carefully remove washer fluid hose - 9 - from connecting pipe - 6 -.
    - Remove nuts - 8 -.
    8 Nm (71 in. lb)
    - Remove wiper motor - 1 -.
    Installing
    - Install in reverse order of removal.
    Note:
    When installing rubber seal - 2 -, carefully insert into hole in rear window - 3 -.
    Rear washer jet, removing and installing
    - Carefully pry off cap for jet using screwdriver.
    - Carefully remove washer fluid hose -9- from connecting pipe -6-.
    - Remove mounting bolts (7x, T10) (arrows) and remove motor cover -10-.
    - Using combi-wrench carefully pull out connecting pipe -6-.
    - Remove rear washer jet -4- toward front from connecting pipe -6-.
    - Replace rear washer jet and insert with rubber seal in previously installed connecting pipe.
    Note:
    Install jet with the jet opening facing directly upward.
    [e]Imagestationin kuviin ei voi suoraan linkittää, muutin kopioitaviksi linkeiksi /Jarkko
    [ee] osoitteet pitää siis kopioida osoiteriville
      Kiitos, kuvista oli todella apua.
      Kyseisessä tapauksessa kiinnikkeet tosin olivat omassa autossani (vm.2001) sellaiset metalliset kaksinkerroin taitetut hakaset jotka on kai tarkoitettukin voimalla irroitettavaksi. Lisäksi hakaset olivat hieman eri paikassa kuin kuvissa.
      Purettuani verhoilun ja avattuani pyyhkijän moottorin takakannen selvisi että messinkiputki pyyhkijän akselin sisässä oli poikki. Siten vesi pääsi pyyhkijän akselia pitkin väärään suuntaan.
      Valitettasti putkea ei löytynyt varaosanana joten jouduin hankkimaan koko pyyhkijäpaketin.
      Passattin joihinkin vuosimalleihin löytyy muovista vastaavaa putkea joka ei kuitenkaan sellaisenaan käy tuohon Audin systeemiin.
        Sama ongelma täällä, löytyisikö noita kuvia vielä jostakin..
        Kiitos
        Edit: Toimii kuvat, tuo peerguardian blokkas vain tuon osoitteen =)
          täällä saatiin sama diagnoosi. Joutuu varmaan tilaamaan uuden moottorin tuolta saksanmaalta.
          Osa nro:8L09557118B , suomessa 120?
            Alkuperäinen kirjoittaja rannila
            Removing
            Installing
            Removing
            8 Nm (71 in. lb)
            Installing
            Note:
            Note:
            Moi,
            Ei löytyisi sulta myös A4 Avanttiin (B6) vastaavia kuvia (takaluukun verhouksen irroitus & takalasin vinkkarin irroitus)?
              Missähän voisi olla vika kun avantin (A6 avant -00) takaluukun aukaisee niin se takaluukun valo vain vilkkuu (siis se valo mikä on tuossa ylempänä olevassa kuvassa numero 8).
              Kuulostaa ihan siltä kuin jokin rele tms nakuttaisi siellä luukussa. Ja nakutus loppuu vasta kun luukun laittaa kiinni. Valo on poissa paikoiltaan ja nakutusta tulee silti muutaman kerran kun luukun aukaisee. Valo siis vilkkuu nopeasti. Olisi tarkoitus tässä lähipäivinä tutkia asiaa vähän tarkemmin.
              Edit: aattelin että topicci ois oikee paikka...
                Löytyisikö jostain toimivat kuvat, pitäisi itsekin irrottaa tuo luukun verhous.
                Edit. Homma hoidossa, lähti irti.
                Viimeksi muokannut PK; 13.12.2009, 12:53.
                  Imagesteissönillä on lappu luukulla. Olisiko noita piirroksia missään muualla, taitaa olla sama vaiva itselläkin.
                    Moi,
                    Minulle kelpaisi kans tämä.
                      kts liitteet, niissä on B6 takaluukun verhouksen ja pyyhkijämoottorin irroitus- ja kiinnityssulkeisten ohjeet.
                        Kuvia Audi B6 takakontista
                        Löytyisikö keneltäkään kuvia kontista? Pissii meinaan vahvarin ja subbarin päälle takalasin pesin ja pitäisi purkaa konttia.
                          Noista vanhoista projektikertomuksista (vetokoukkuasennukset) löytyy, ja pikahakuna vaikka tästä. On b7, mutta muistikuvani mukaan on täysin sama.
