VAG-COM ilmoitti alla olevat vikakoodit. Voisiko joku fiksu kertoa mistä on kysymys. Ongelmia minulla on ollut auton käynnistyksessä kun ajonestovalo ei tahdo sammua... auto on audi a6 2.5 tdi-97. Kiitoksia neuvoista jo etukäteen!
Address 01 -------------------------------------------------------
Controller: 4A0 907 401 P
Component: 2,5l R5/2VT EDC HS D30
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00053
Shop #: WSC 02314
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
41-00 - Blocked or No Voltage
Address 17 -------------------------------------------------------
Controller: 4A1 919 033 HP
Component: C4-KOMBIINSTRUMENT D20
Coding: 00050
Shop #: WSC 00012
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 25 -------------------------------------------------------
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0TD037949 D77
Coding: 00000
Shop #: WSC 32271
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
End -------------------------------------------------------
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Readiness: N/A
Coding: 00053
Shop #: WSC 02314
1 Fault Found:
Coding: 00050
Shop #: WSC 00012
No Faults Found
Coding: 00000
Shop #: WSC 32271
1 Fault Found:
01176 - Key
