nyt tuli tälläistä vikailmoitusta audiin, mitähän mahtavat tarkoittaa?
olen aika uusi audin omistaja,ei vielä kokemusta audeista :)
kiitokset jo etukäteen!
Address 01 -------------------------------------------------------
Controller: 8E0 909 518
Component: 1.8L R4/5VT G 0001
Coding: 0011701
Shop #: WSC 00103
2 Faults Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 008 - Implausible Signal - Intermittent
16985 - Internal Control Module: Memory Check Sum Error
P0601 - 001 - Upper Limit Exceeded
Readiness: 0000 0000
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 A
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 01100
Shop #: WSC 24500
WAUZZZ8E62A155499 AUZ6Z0A0284138
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AD
Component: Komfortgerát T85 0315
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Coding: 0011701
Shop #: WSC 00103
2 Faults Found:
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 01100
Shop #: WSC 24500
1 Fault Found:
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
