Elikkäs ESP valo syttyy aikalailla heti startissa, sitten saatta kadota hetkeksi vain palatakseen takaisin.
Samalla ilmestyy teksti ESP fault, see owners manual.
Alla osin referoituna vikalista...
Koitin hakua ja googlea, mutta ajattelin kuiten laittaa tämän tänne, josko joku osaisi antaa vihjettä mistä alan kaivamaan.
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0010
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 31000 205 66410
VCID: 1A3B34E3D56A62CE7A7-804F
006464 - Powertrain Databus
P1940 - 001 - Missing Message from Control Module for Battery Monitoring - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 254
Reset counter: 255
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:24
Freeze Frame:
RPM: 1134 /min
Torque: 187.2 Nm
Speed: 0.0 km/h
Duty Cycle: 13.9 %
Voltage: 13.68 V
(no units): 1224.0
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 199
Reset counter: 255
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:26
Freeze Frame:
RPM: 1134 /min
Torque: 175.5 Nm
Speed: 1.1 km/h
Duty Cycle: 12.0 %
Voltage: 13.60 V
Bin. Bits: 00101100
Torque: 312.0 Nm
005785 - Powertrain Data Bus
P1699 - 001 - Missing Message from Steering Wheel Electronics - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 221296 km
Time Indication: 0
Date: 2018.02.21
Time: 10:03:13
Freeze Frame:
RPM: 1848 /min
Torque: 249.6 Nm
Speed: 50.4 km/h
Duty Cycle: 29.9 %
Voltage: 13.38 V
Bin. Bits: 00101100
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0100
Revision: --H01--- Serial number: 0091696
Coding: 0000001
Shop #: WSC 02331 785 00200
VCID: 285F1E2B9B06C05EFC3-807D
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Reset counter: 40
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:25
Freeze Frame:
RPM: 1120 /min
RPM: 128 /min
RPM: 32 /min
(no units): 7.0
(no units): 41.0
Temperature: -11.0°C
T.B. Angle: 13.3°
18275 - Powertrain Data Bus
P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Reset counter: 40
Mileage: 221296 km
Time Indication: 0
Date: 2018.02.21
Time: 10:03:13
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0037256
Shop #: WSC 45896 141 14353
VCID: 2D51EF3FB4E4E5760F5-8078
18265 - Load Signal
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 202
Reset counter: 175
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:24
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0028
Hex Value: 0x01A9
Hex Value: 0x00FF
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Shop #: WSC 02335 785 00200
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 45
Reset counter: 174
Mileage: 221312 km
Time Indication: 0
Date: 2018.02.21
Time: 10:14:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 179
Reset counter: 174
Mileage: 217140 km
Time Indication: 0
Date: 2017.12.10
Time: 15:04:00
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 080080521000B2
Coding: EDFE73C61B1104
Shop #: WSC 02325 785 00200
VCID: 275D1D179618CF26F59-8072
Freeze Frame:
Fault Priority: 1
Reset counter: 175
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:14
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 48
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:39:22
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 1
Fault Frequency: 48
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:39:22
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 174
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:40:45
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 54
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:41:22
Coding: 0011372
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:24
Freeze Frame:
RPM: 1134 /min
Torque: 187.2 Nm
Speed: 0.0 km/h
Duty Cycle: 13.9 %
Voltage: 13.68 V
(no units): 1224.0
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:26
Freeze Frame:
RPM: 1134 /min
Torque: 175.5 Nm
Speed: 1.1 km/h
Duty Cycle: 12.0 %
Voltage: 13.60 V
Bin. Bits: 00101100
Torque: 312.0 Nm
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 221296 km
Time Indication: 0
Date: 2018.02.21
Time: 10:03:13
Freeze Frame:
RPM: 1848 /min
Torque: 249.6 Nm
Speed: 50.4 km/h
Duty Cycle: 29.9 %
Voltage: 13.38 V
Bin. Bits: 00101100
Coding: 0000001
2 Faults Found:
18265 - Load Signal
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:25
Freeze Frame:
RPM: 1120 /min
RPM: 128 /min
RPM: 32 /min
(no units): 7.0
(no units): 41.0
T.B. Angle: 13.3°
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 221296 km
Time Indication: 0
Date: 2018.02.21
Time: 10:03:13
Coding: 0037256
18265 - Load Signal
Freeze Frame:
Fault Priority: 3
Reset counter: 175
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:24
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0028
Hex Value: 0x01A9
Hex Value: 0x00FF
Coding: 0012121
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 45
Reset counter: 174
Mileage: 221312 km
Time Indication: 0
Date: 2018.02.21
Time: 10:14:00
Freeze Frame:
Fault Priority: 2
Reset counter: 174
Mileage: 217140 km
Time Indication: 0
Date: 2017.12.10
Time: 15:04:00
Freeze Frame:
Fault Priority: 1
Reset counter: 175
Mileage: 221295 km
Time Indication: 0
Date: 2018.02.21
Time: 10:02:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 48
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:39:22
Freeze Frame:
Fault Priority: 1
Fault Frequency: 48
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:39:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 174
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:40:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 54
Reset counter: 175
Mileage: 221432 km
Time Indication: 0
Date: 2018.02.21
Time: 11:41:22
