Huollon nollaus VAG-COMilla ? Audi A2 1.6 FSI
  • Huollon nollaus VAG-COMilla ? Audi A2 1.6 FSI
    Täys huolto tehdä ja nollata huollot sen jälkeen mutta miten ?
    Löysin VW tarkoitettuja ohjeita mutta sielläkin on paria vaihtoehtoa?
    Tässä ohjeet mitä löysin:
    [Select]
    [17 - Instruments]
    [Adaptation - 10]
    Enter the correct channel from the chart below in "Channel Number"
    [Read]
    The "Stored Value" is the current value for that channel.
    Enter the "New" value of from the chart below.
    [Test]
    [Save]
    So, for example, to reset the OIL reminder in a Golf IV, save a "New" adaptation value of 00015 to channel 10.
    Channel Indicated on Display Contents "New" Adaptation value to reset
    Polo 6N Golf4 Passat B5 Lupo -2002 New Beetle Bora Transporter T4
    10
    OIL Distance which can be reset 00150 00015 00015 00150 00015 00015 00015
    11
    INSP Distance which can be reset 00300 00030 00030 00300 00030 00030 00030
    12 INSP Time which can be reset 00360 00036 00037 00360 00036 00036 00037
    Nollasin huoltonäytön tällä komennolla: Channel 02 - set to 0 to reset
    Nyt auto näyttää että seuraavaan huoltoon on 15 000 km ? Kuinka saan sen nollattua että huoltoon on 30 000 ? Autossani on käytössä Longlife järjestelmä...
    Nämä tiedot löysin ross-techin sivulta:
    Audi Service Interval Reminders
    Updated 29 Mar. 2005
    Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
    Audi has included a Service Interval Reminder that includes oil mileage interval, the service mileage interval, and the service time interval. To reset the Service Reminders using VAG-COM:
    Select Control Module > [Select]
    [17 - Instruments]
    [Adaptation - 10]
    1995-1997 (and maybe part of 98):
    Channel 05 should be the distance until the next Oil Service.
    It is in thousands of kilometers. Let's say you want the Oil
    Service light to come on in 5000 miles. That would be 8000 km.
    Put the value 8 into channel 05. The "standard value" used by the US
    dealers would be 12 (7500 miles).
    Channel 06 should be the distance until the next In-1 Service.
    Same units as above. Standard value would be 24 (15,000 miles).
    Channel 07 should be the time until the next In-1. In-1 lights
    up based on time or distance, whichever comes first. This is in
    10's of days. Standard value would be 36 for 360 days.
    Channel 08 would be time until the next In-2. In-2 is based
    strictly on time. Standard value is 72 for 720 days (about
    two years).
    1998 and Newer:
      Menisköhän samaan tyyliin kuin LongLife volkkareissa, ohjeet sieltä Ross-Techin volkkarisivun lopusta:
      Auxiliary work with Long Life service:
      Resetting the value in channel 2 will automatically reset fixed service intervals (15000/30000/12 months)
      If conventional engine oil was used, then this is all that needs to be done.
      If Long Life oil is used, then adaptation must be done the vehicle according to following table with respect to the oil quality
      Ja se taulukko siis tuon sivun lopulla:
      http://www.ross-tech.com/vag-com/cars/vw_sri.html
      Eli toisin sanoen käpistellään niitä kanavia 43-45.
        Mistäs tietää onko longlife käytössä?
