antaa kyseiset vikakoodit
Wednesday,07,September,2016,20:41:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: License Plate: BIN-354
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Control Module Part Number: 8E0 614 111 C
Component and/or Version: ABS/ASR 5.3 FRONT D00
Software Coding: 00003
Work Shop Code: WSC 02315
VCID: 1E3338F39A420EEE86F-5000
1 Fault Found:
00761 - Fault Code(s) Stored in Engine Control Module
35-00 - -
Wednesday,07,September,2016,20:15:22:62939
Mileage: 262570km-163153mi Repair Order:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4B0 907 552 C
Component and/or Version: 2.4L V6/5V MOTR AT D03
Software Coding: 04152
Work Shop Code: WSC 02324
VCID: 2541171FBF14DD36C75-4A3A
6 Faults Found:
17645 - Fuel Injector for Cylinder 1 (N30)
P1237 - 35-00 - Open Circuit
17646 - Fuel Injector for Cylinder 2 (N31)
P1238 - 35-00 - Open Circuit
17647 - Fuel Injector for Cylinder 3 (N32)
P1239 - 35-00 - Open Circuit
17648 - Fuel Injector for Cylinder 4 (N33)
P1240 - 35-00 - Open Circuit
17649 - Fuel Injector for Cylinder 5 (N83)
P1241 - 35-00 - Open Circuit
17650 - Fuel Injector for Cylinder 6 (N84)
P1242 - 35-00 - Open Circuit
Readiness: N/A
autoon vaihdettiin vain tulpat ja ilmanputsari.
onko nyt sitten ruiskuboksi sökö vai mistä kannattas vikaa etsiä.
ja onko boksi tuolla vänkärin lattiamaton alla vai missä
1 Fault Found:
35-00 - -
6 Faults Found:
Readiness: N/A
