Noniin, vier kävi lukemassa mulle koodit, kiitos siitä ja seuraavia tuloksia tuli:
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No SW: 8E0 909 518 AL HW: 8E0 909 018 A
Component: 1.8L R4/5VT 0003
Coding: 0011711
Shop #: WSC 66565 257 00032
VCID: 7AADF85440C747DBE95-5160
VINID: 9D196AAAA2151444411401421076FDC059
2 Faults Found:
17700 - Map Controlled Engine Cooling Thermostat (F265)
P1292 - 004 - Open Circuit - Intermittent
17939 - Camshaft Timing Adjustment
P1531 - 004 - Open Circuit - Intermittent
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04475
Shop #: WSC 06435
VCID: 2615FC24E1FF133BFDD-51F2
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AB
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
VCID: 619FAF38C851B403C8F-513C
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul NDL 0517
Coding: 00002
Shop #: WSC 63251
VCID: 35372B682C5968A3447-4B00
2 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
57-00 - Electric Circuit Failure
01496 - Bulb for Fog-Lamps; Left (L22)
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 N
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01101
Shop #: WSC 00006
VCID: 2F3B1900CE0552730EB-5160
WAUZZZ8E54A150524 AUZ6Z0C0354015
6 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
00562 - Sensor for Oil Level/Temperature (G266)
29-00 - Short to Ground
27-00 - Implausible Signal
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Address 46: Central Conv. Labels:. 8E0-959-433-MIN.clb
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63251
VCID: 015F8FB828111403A8F-4B00
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
No fault code found.
End----------(Elapsed Time: 05:40, VBatt start/end: 13.4V/13.8V)-----------
Olikin nyt sitten ilmeisesti hajottanut tuon nokan tunnistimen ohi mennen taas tai sitten "uudessa" johtosarjassa jonkinlaista häiriötä. Osaisiko arvon raati sanoa tuosta ecusta? Meniskö johtovikana vai onko ecu antamassa viimeisiään?
Coding: 0011711
2 Faults Found:
Coding: 04475
Shop #: WSC 06435
1 Fault Found:
Coding: 00000
Shop #: WSC 63251
1 Fault Found:
Coding: 00002
Shop #: WSC 63251
2 Faults Found:
Coding: 01101
Shop #: WSC 00006
6 Faults Found:
01304 - Radio
Coding: 06976
Shop #: WSC 63251
