A 6 2.4 100kw??
    A 6 2.4 100kw??
    Mikähän mahtaa olla otsikon mukainen moottorityyppi? Olen bongannut ko malleja esim Saksasta. Koko on siis 2.4l, mutta tehot vaan 100kw. Vääntö kait kuitenkin sama kun 165 hv mallissa.. Miten ko moottori "kuristettu?"
    Moottorin tyyppi taitaa olla ALW. En kyllä tiedä miten on sitten tehoja tiputettu.
      Lisäys edelliseen ALW ja ASM
        http://www.dsv.su.se/~mad/power.html
        Another interesting engine is the "de-chipped" 100 kW 2.4 litre V6. It actually has more torque than in its original 121 kW ancestor. The 100 kW was a chip "anti-trim", i.e. the physical engine is exactly the same as the 121 kW but the control program was modified to give less power, albeit not the reduction Audi claimed. And since the torque is better, the engine is a very good choice. It seems the second hand market for Audi A6 has recognized this fact and rates them about the same, even though the 100 kW was a lot cheaper to buy first hand. To create an artificial difference between them, the 100 kW came with much less options, such as no 4WD and no automatic transmission.
        2.4 / V6 cyl. (100 kW) 136 hp 153 hp 230 Nm 229 Nm
        2.4 / V6 cyl. (121 kW) 165 hp 166 hp 230 Nm 216 Nm
