Audi 80 1.6 S Automatic is a sedan/saloon that has 5 seats, front wheel drive (FWD) and 4 doors. This model has been initiated in 1988. The measurements of the vehicle are as follows: height - 1395.00 mm, width - 1695.00 mm, length - 4395.00 mm. Furthermore, the wheelbase is 2545.00 mm, the front track is 1410.00 mm and the rear track is 1430.00 mm. 130.00 mm is this vehicle's ground clearance. The engine of Audi 80 1.6 S Automatic is 1595 cc, 4-cylinder with 2 valves per cylinder, naturally-aspirated, single overhead camshaft (SOHC). It has a longitudinal alignment and is installed in the front of the vehicle. The cylinders are inline-arranged. The length of the piston stroke is 77.40 mm and the diameter of the cylinders is 81.00 mm . The compression ratio is 9.00:1. The maximum power and maximum torque produced by the engine are 55 kW / 75 ps at 4500 rpm and 140 Nm at 2500 rpm respectively. The model's fuel system is carburettor. The oiling system of the engine is wet sump. The vehicle can accelerate for 15.90 s from 0 to 100 km/h. The Audi 80 1.6 S Automatic has an automatic 3-speed transmission. The top gear ratio is 1.00:1. 3.73:1 is its final drive ratio. This automobile has an urban fuel consumption of 6.2 l/100 km, extra urban of 7.6 l/100 km and combined fuel consumption of 10.5 l/100 km. The fuel tank has a capacity of 68.0 l. The front wheels size is 5.5J x 14. The size of the rear wheels is 5.5J x 14. The type/size of tyres in the front is 175/70 SR 14. The tyres in the rear are 175/70 SR 14. The front brakes are provided with disks. The rear brakes are fitted with drums, servo assistance.
Ja miten nuo 3-loviset tms vanhat tomaatit kestää? Varmaan suhteellisen vaikeita löytää aivan timmissä olevaa.
Mut halvalla mukava kaupunkipyöritin kuitenkin tollasesta irtoo?
Btw mitä eroo on Urbanilla ja Extra urbanilla? Extra urban on pellolla ajamista?
Kannattas silloin jo hankkia ihan periaatteen vuoksi, jos vaan kunnossa on.
Aatteleppa ei heti ajele samanlainen vastaan ja olishan siinä tyyliä, kun semmosella ajelis. (harrastusta)
Ja sämpylä on muutenkin ihan kiva vekotin:)
Viimeksi muokannut kapaz; 1.5.2011, 07:43.
Perustelu: noita kirotusvihreitä korjailin
En kyllä uskalla kuvitellakaan miten laiska tuo automaatti 1.6 on.
Mulla on tuo työmatka kulkuneuvona tollanen 1.6 manuaali ja kyllä sillä menee aika pitkä aika moottoritiellä 120km/h :D
Jos kovempaa pitää päästä niin alamäkeä tarvii vauhin keräämiseksi.
Tuo on kyllä auto mikä pitäisi ottaa nyt talteen harvinaisuuden vuoksi. Tuskin noita maailmallakaan on säästynyt liiemmälti. Rahallista arvoa ei ko. laitteella ole koskaan mutta olis(ihan tuollaisessa oma fiiliksensä. Täydellinen kontrasti S2:lle (joka tosin taisi aina olla B4) eli parempi kontrastipari olisi typ89 sedanin top-of-the-range -malli (90 2.3 20V quattro?).
Jäi tuon oman edellisen viestin "haukut" harmittamaan :D Joten nyt vähän kehujakin..
Ikinä ei ole huolettomampaa autoa ollut. Vähän kun muistaa joskus öljyä koneelle antaa niin taas mennään. Jakohihna on tainnut mennä jo lähemmäs 100tuhannella yli vaihtovälin mut pari kertaa kattonu kuntoa ja todennu et hyvä on(1.6.ssa ei venttiilit ja mäntä kohtaa ollenkaan). Alustanosat uusin muutama vuos sitte ja leveemmät renkaat on alla niin on jopa erittäin hyvä auto ajaa!
Tulee tällä hetkellä ajettua reilu 200km päivässä työmatkaa tuolla ja tolla nelkulla se ei bensansyönnin takia tule kysymykseen.
Kyllä tuolla pärjää jos hyväksyy sen että joku 112 Lada 16v kiihtyy 0-100km/h 7 sekuntia nopeammin 15hv tehokkaammalla koneella ja syö matka-ajossa 5,6l/100km.Puhumattakaan 20cm:n maavarasta.
