SAFE teksti mittaristossa?
  • SAFE teksti mittaristossa?
    Muutaman kerran on tullut SAFE teksti mittaristoon trippilukeman tilalle tuossa kasissa. Mitähän tuo käytännössä meinaa? Tänään tuo tuli viimeksi ja kun sattui läppäri olemaan mukana katsoin vikakoodit, mutta käsittääkseni mitään vakavaa ei löytynyt:
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131 K
    Component: FBS AUDID3 H07 0160
    Revision: 01604707 Serial number: AUX3Z0E7372662
    Coding: 0410624
    Shop #: WSC 02311 785 00200
    VCID: D8B4183E127B
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00190 - Driver's Door Handle Touch Sensor (G415)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 206
    Mileage: 66784 km
    Time Indication: 0
    Date: 2010.03.01
    Time: 08:53:20
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 731 A HW: 4E0 035 729
    Component: Interfacebox H43 1200
    Revision: 00000000 Serial number: 343EK057561324
    Coding: 0000001
    Shop #: WSC 67393 141 57394
    VCID: 1F46F322B7D5
    Part No: 4E0 910 609 C
    Component: Bedienteil MMI H42 0100
    1 Fault Found:
    02095 - Component Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 234
    Time Indication: 1
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
    Component: DSP-Amp.-High H13 0440
    Revision: PROD_01 Serial number: 00000000001659
    Coding: 0000012
    Shop #: WSC 02313 785 00200
    VCID: 254AE1CA9589
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 234
    Time Indication: 0
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
    Component: TUNER EU/US/RDW H42 0480
    Revision: 00000000 Serial number: 396I.057527138
    Coding: 0000001
    VCID: 234EFFD29BBD
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 79329 km
    Time Indication: 0
    Date: 2010.07.07
    Time: 16:26:38
    Eiköhän se ole rammarin turvalukitus. Toimiiko radio yms soittimet?
      No radio ainakin toimi, muuta en kokeillut. Ja häviää näytöstä jos auton sammuttaa ja käynnistää uudelleen. Minkäslainen ilmoitus moottorin safe modesta tulisi, ja näkyisikö se aina moottorin vikakoodeista? Mutta se ilmeisesti tuntuisi kulkupuolessakin niin että huomaa?
