Missä audin moottorissa 19mm veivin tappi?
  • Missä audin moottorissa 19mm veivin tappi?
    Missä audin moottorissa käytetty 19mm veivin yläpäätä?
    http://forums.vwvortex.com/zerothread?id=2666114
    AEB, AGU, AJQ, APP, APX, BAM, AMU, AUL, APX, AWD and APH engine codes have 20mm wrist pins, all others have 19mm wrist pins.
    AEB and AWD (all 20mm wrist pin motors??) had 16v style rods (144mm long, 20mm wrist pins). The pauter 16v rods drop right into the stock pistons for those 2 engine codes without requiring modification.
    All aftermarket pistons have 20mm wrist pins and mate to any aftermarket rod, pauter, eagle/scat, crower, manly etc etc.
    All of the later cars have 19mm wrist pins and tapered wrist pin areas so the 16v style rods dont drop in. Pauter makes a modified rod with a tapered wrist pin area and re bushes them to 19mm. They are the same price or a little more then the regular rods depending where you get them.
    For engines with 19mm wrist pins the only option to keep stock pistons is pauter tapered rods
