Vikakoodeja
  • Vikakoodeja
    Profiilini autossa alkoi samaan aikaan palamaan EPS:n ja ABS:n varoitusvalot, VAG.con antoi seuraavan vikakoodin
    [SIZE=3][FONT=Times New Roman]Chassis Type: 4B - Audi A6 C5[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 01 -------------------------------------------------------[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 907 401 A [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: 2.5l/4VTEDC G000AG D00 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 01016[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Shop #: WSC 02325[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] 00014059 130 106EC150_1.R75894989181[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]1 Fault Found:[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]01441 - Low Fuel Level Sensor (G210)[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] 27-00 - Implausible Signal[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Readiness: N/A[/FONT][/SIZE]
    Tekstin mukaan se ei liity merkkivaloihin. Controll Modulin läpiajo antoi seuraavan raportin:
    [SIZE=3][FONT=Times New Roman]Address 01[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Protocol: KW1281[/FONT][/SIZE]
    [FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
    [SIZE=3][FONT=Times New Roman]Address 02[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 927 156 D [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: AG5 01V 2.5lTDI RdW 1010[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 00001[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Shop #: WSC 00000[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 03[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 907 389 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: ABS/ESP allrad D57[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 06357[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 08[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Note: Excessive Comm Errors[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Skipping Address 15-Airbags[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 17[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 920 900 CX [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: C5-KOMBIINSTR. VDO D14 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 00040[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Shop #: WSC 42234[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 25[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: Bitte Adress[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: e 17 eingeben [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 33[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Protocol: ????[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: OBD-II/EOBD, KeyWord:0808[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 34[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 907 553A[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: - 2C1A1 X030 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 25500[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Shop #: WSC 51209[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 35[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4B0 962 258 D [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: Zentralverriegelung D34[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 06721[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 55[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4Z7 907 357 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: dynamische LWR D05[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 00030[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 56[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Controller: 4B0 035 186 [/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Component: Radio 0001[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Coding: 00201[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Shop #: WSC 01059[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman]Address 7E[/FONT][/SIZE]
    [SIZE=3][FONT=Times New Roman] Protocol: KWP2000[/FONT][/SIZE]
    Ovatko nuo koodit vikakoodeja ja jos ovat mitä ne tarkoittaa ja viittako niistä mikään palaviin varoitusvaloihin
    Otappa uusiksi koko homma ja ota mäkeen nuo fonttiattribuutit ja ajappa full scan niin katotaan uusiksi.
      Scan toiminnolla tuli vain vikakoodi
      1 Fault Found:
      Readiness: N/A
      Minulla on Ross techin ilmainen ohjelma, löytyykö sillä kaikki vikakoodit
        Varmasti siellä on muitakin koodeja jos ESP ja ABS valo palaa.
        Ilmaisella saa kaikki koodit, mutta selityksiä ei. Näyttää yhden koodin selväkielisenä ja loput numerorimpsulla. Nyt pitäisi ne numerorimpsut saada sieltä.
        Tälläinen rivi tulee sharewarella:
        17763 - Shareware Version. To Decode all DTCs
        P1355 - 35-10 - Please Register/Activate - Intermittent
        Ja tuosta nyt pitäisi saada sulta nuo rivit, koska noista 17763 ja P1355 numeroista pystyy katsomaan vian rosstechin wiki sivuilta ilman että ohjelma on rekisteröity.
          Kokeilin vielä tänään ja tuli ainoastaan tuo aikaisemmin kirjoittamani koodi ja sen jälkeen tulee ikkuna, jossa viesti, että pitää rekisteröityä ja aktivoida. Vag.com ohjelmani on 311.2 ja olen imuroinut sen noin kaksi vuotta sitten ja kaapeli Elekmalta ostettu OBD 2 / usb
            Naapurin Esko kehu että jostain ryssän sivuulta tuoho versioon löytyy kräkki. Minähän en asiasta tiedä mitään.
              Näät ne oikeat koodit kun saat toimivan ohjelman tai viet huoltamoon luetuttamaan ne koodit.
                Mistä ja mikä ohjelma kannattaa asentaa, jotta saisi kaikki vikakoodit.
                  Meni just nyt lukkoon:
                  - otsikointi/aihe
                  - profiilin auto
                  - ensimmäisen viestin olisi voinut korjata
                  - laittomien versioiden ohjelmien latailujen kyselyt
                  - haun käyttäminen
