A6 C7 Alustan vikavalot
  • A6 C7 Alustan vikavalot
    Eli palaa TPMS, Air suspension fault, headlight range fault, esc fault,parking brake vikavalot. mistä nämä voi johtua?
    Akku vaihdettu vikojen jälkeen ja koodattu.
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
    Component: ESP PREMIUM H09 0450
    Revision: -------- Serial number: --------------
    Coding: 27A6DF01E465FB80FB00
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ESPPremiAU57X 004039
    ROD: EV_ESPPremiAU57X_004_AU57.rod
    VCID: 3A2D24F55CDE824A517-806E
    9 Faults Found:
    0055 - Function Restricted due to Missing Message(s)
    U1111 00 [00001001] - -
    [ComScl_PDU_Fahrwerk_02_Timeout]
    Confirmed - Tested Since Memory Clear
    0657 - Function Restricted due to Missing Message(s)
    [ComScl_PDU_Fahrwerk_03_Timeout]
    0518 - Function Restricted due to Missing Message(s)
    U1111 00 [10001001] - -
    [ComScl_PDU_SARA_06_Timeout]
    MIL ON - Confirmed - Tested Since Memory Clear
    0785 - Function Restriction due to Faults in Other Modules
    U1113 00 [00001001] - -
    [SCL_LWR_Hoehenwert_VL_Error]
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0130
    Revision: 20012002 Serial number: 00000001784142
    Coding: 2600E01040749FE08981008300001D0CCF9CE7082E09020100 0004606101
    VCID: 6E85D8A550961EEABDF-803A
    Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
    Component: WWS57X 130909 H36 0080
    Serial number: 130924160745
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 21800964
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
    Component: E1 - LDS H07 0044
    Serial number: 27 09 2013 00000527
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H03 0002
    Serial number: 2218CEC6000000000001
    1 Fault Found:
    00471 - Control Module for Elect. Regulated Dampers (J250)
    004 - No Signal/Communication
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H43 0040
    Revision: -------- Serial number: 003JG00F0JH3 Dataset Number: 4G0909602H 0002
    Coding: 3032343631334E303431554A304C34473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 363530C568C6662AB5F-8062
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB401G50LNG4935
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 3585HRB400M50J5QGHS3
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 3515JRB405F2861ED1S$
    Passenger side rear thorax airbag crash sensor:
    Serial number: 3525JRB401250N8KFA4Z
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB400O50NQQ81TH
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB400M50NQQQ8U%
    3 Faults Found:
    1049093 - Databus
    U1123 00 [00001001] - Received Error Message
    [CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
    1049094 - Databus
    [CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
    1049095 - Databus
    [CAN: 0x101 ESP_02 error value ESP_Gierrate]
    Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
    Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
    Component: J533--Gateway H13 0050
    Revision: -------- Serial number: 00000001118221 Dataset Number: 4G0909515H 0067
    Coding: 00CD077D00
    GVL: FDA3F900DE65600D0000
    ASAM Dataset: EV_GatewPkoUDS 001019
    ROD: EV_GatewPkoUDS_001_AU57.rod
    VCID: 72BDCCD5442E3A0A597-8026
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 3577501403
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
    Component: J532_DCDCStab H23 0021
    Serial number: 1307120000000000071A
    4 Faults Found:
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
    U0100 00 [00001000] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    5014 - Ride Level Control Module
    U0132 00 [00001001] - No Communications
    6655 - Sensor electronics control module
    U1077 00 [00001000] - No communication
    0274 - FlexRay-Data bus
    U1048 00 [00001000] - defective
    [Konzern-Datenbus Flexray defekt]
    Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
    Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
    Component: FLA H04 0012
    Revision: AA001002
    Coding: 02018264747464545425363E00
    VCID: 7CA1E2ED16EA7C7A03B-8028
    1 Fault Found:
    03455 - Function Restriction due to Faults in Other Modules
    000 - -
    Address 34: Level Control
    Cannot be reached
    Address 3B: Sensor Elect.
    Cannot be reached
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
    Component: EPB-4 H03 0014
    Revision: -------- Serial number: 00000000844080 Dataset Number: 4G0909522D 0007
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2C0112ADA68A2CFAD3B-8078
    2 Faults Found:
    459264 - Function Restriction due to Faults in Other Modules
    U1113 00 [10001001] - -
    [FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
    463616 - Function Restriction due to Faults in Other Modules
    [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
    Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
    Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
    Component: ....LWR12.... H02 0010
    Serial number: 131009-0004-044
    Coding: 11226F101002A300
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 2D071FA99D9025F2C45-8078
    1 Fault Found:
    120580 - Function Restricted due to Missing Message(s)
    [Timeout CAN-Message Fahrwerk_01_FR (0x108)]
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 666 K HW: 4G0 035 666 H
    Component: H-BN-EU H51 0732
    Revision: -------- Serial number: 189J/0D7561211
    Coding: 050100010003F3ED0590AB3E00000003E00001020000000000
    VCID: 303906DD8A22481AEF3-8064
    Subsystem 1 - Part No: 8R0 060 884 BC
    Component: EUR 2013/2014 1603
    Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
    Component: DU8 C7 SV H43 0021
    Serial number: AUZ8ZDDD002PXKM
    Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
    Component: E380 BDT C7 H11 0204
    Serial number: 90349MJ4000HE
    Subsystem 4 - Part No: 8R0 060 961 F
    Component: CD-Database 5298
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
    000 - - - Intermittent
    03278 - Functionality Limited due to Missing Messages
    Voisko olla can-väylän liitin huonosti jossain, esim alustan ohjaimella?
      Tai sitten jokin ohjain sotkee CAN-väylää (hapettunut ohjainboksi, liitin tms.), koska useita vikakoodeja CAN-dataongelmista.
      34 ja 3B ainoat, johon VCDS ei saa lainkaan yhteyttä, niin niistä voisi lähteä liikkeelle. Liitin irti ja katsomaan muuttuuko 19: CAN Gateway vikakoodit.
