Ostin auton viikko sitten ja ei pitänyt mitään vikaa olla, eikä silloin ollutkaan. Pari kertaa herjas moottorin vikavaloa ja sammu itsekseen, nyt se tuli jäädäkseen. Eli löytyisikö pullakaffen verran ainaki neuvontaa ja apuja auton kans?
3.0tdi -05 vikakoodinluku apuja Tampereelta?
Kerkes unohtaa tänne laittaa, kyseiset viat havaittu.
5 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 273669 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 12.16 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 001 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 30
Reset counter: 255
Mileage: 273691 km
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Torque: 35.1 Nm
Speed: 0.0 km/h
Voltage: 12.16 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 008 - Electrical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 273770 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Temperature: 79.2°C
Duty Cycle: 80.9 %
Voltage: 12.39 V
Duty Cycle: 0.4 %
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 273780 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 218.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.86 V
Duty Cycle: 15.0 %
Temperature: 18.9°C
004472 - Linear O2 Sensor; Pump Current
P1178 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 273797 km
Time Indication: 0
Freeze Frame:
RPM: 2016 /min
Torque: 222.3 Nm
Speed: 115.4 km/h
Duty Cycle: 1.0 %
Mass Air / Rev.: 640.4 mg/str
(no units): 0.80
(no units): 8.0
Pystyiskö joku suomentaa, vähä onnetonta puhelimen välityksellä kaivella ross tech: sivuilta. Täytynee investoija seuraavana joko taas läppäriin tai jos joku viittii suomentaa nii osiin. Tuki kumi oikeelle ja kutosen hehkun ymmärrän mut muut jää epäselväksi. Imu läpissä vai moottoreissa vai tangoissako vika?
