Keräsin motivaatiota tuon cruisen toimimattomuuden tutkimiseen ja aloitin seuraavanlaisella ohjeella.
** Switch & wiring
- Connect multimeter between terminal 8 and terminal 10 of control module harness connector
- Push switch towards RES position
If ? ? -> Repair break in wiring or replace switch
Toimii
Connect multimeter between terminal 8 and terminal 4 of control module harness connector
- Press FIX/SET button
Toimii
** Switch for vent valve for brake pedal & wiring
- Connect multimeter between terminal 11 and terminal 5 of control module harness connector
- Move switch to ON position
If ? ? Replace switch or vent valve for brake pedal or repair break in wiring.
Näyttää 125 ohmia ja painettuna 5 ohmia
** Vent valve for brake pedal
- Connect multimete r between terminal 11 and terminal 5 of control module harness connecto
- Position of switch ON
- Operate brake pedal
If 0 ? Replace brake pedal vent valve
** Vacuum pump motor faulty
- Switch ON ignition
- Connect ground to terminal 6 of control module connector
- Supply voltage to terminal 7 using jumper cable
If motor does not run = Vacuum pump faulty or break in wiring
Toimii
** Vent valve in vacuum pump is faulty
- Connect ground repeatedly to terminal 12 of control module connector
- Supply external voltage to terminal 7 using jumper cable
If vent valve does not click = Vacuum pump faulty or break in wiring
If Vent valve clicks = Check speedometer speed signal; wiring diagram
Onko tuon poljinkytkimen toiminta nyt ihan speksien mukainen ja kytkin ehjä? Jarruvalot toimii kyllä. Pitäisikö boxin 12 nastaiseen liittimeen tulla virta johonkin pinniin?
** Switch & wiring
Toimii
Toimii
Toimii
