-11 B8 Adaptiivinen vakkari rikki?
  • -11 B8 Adaptiivinen vakkari rikki?
    Moro
    Osaisiko joku guru sanoa vikakoodin perusteella mikä mun adaptiivista vakkaria vaivaa? Meneeköhän tutka uusiksi. ACC unavailable ja Braking guard off.
    Address 13: Auto Dist. Reg (J428) Labels: None
    Part No SW: 8K0 907 561 HW: 8K0 907 561
    Component: ACC2 H09 0080
    Serial number: 00000000000000
    Coding: 0079B9
    Shop #: WSC 06335 000 00000
    VCID: 6FED878DBED57E4698-803A
    8 Faults Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 13
    Reset counter: 152
    Time Indication: 0
    Freeze Frame:
    Temperature: 13.0°C
    Voltage: 14.21 V
    Bin. Bits: 00000
    Hex Value: 0x044B
    Hex Value: 0x0009
    Speed: 79.2 km/h
    Lateral Accel.: 0.12 m/s^2
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 152
    Time Indication: 0
    Freeze Frame:
    Temperature: 13.0°C
    Voltage: 14.21 V
    Bin. Bits: 00000
    Hex Value: 0x044B
    Hex Value: 0x0010
    Speed: 79.2 km/h
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 152
    Time Indication: 0
    Freeze Frame:
    Temperature: 13.0°C
    Voltage: 14.21 V
    Bin. Bits: 00000
    Hex Value: 0x044B
    Hex Value: 0x0013
    Speed: 79.2 km/h
    02095 - Component Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 25
    Reset counter: 152
    Mileage: 199631 km
    Time Indication: 0
    Date: 2016.02.12
    Time: 23:15:00
    Freeze Frame:
    Temperature: 15.0°C
    Voltage: 14.21 V
    Bin. Bits: 00000
    Hex Value: 0x04F1
    Hex Value: 0x0002
    Speed: 0.0 km/h
    Lateral Accel.: 0.00 m/s^2
    16352 - Control Module - Electrical Error
    014 - Defective
    Freeze Frame:
    Fault Status: 01111110
    Fault Priority: 1
    Fault Frequency: 121
    Reset counter: 112
    Mileage: 199644 km
    Time Indication: 0
    Date: 2016.02.12
    Time: 23:25:54
    Freeze Frame:
    Temperature: 10.0°C
    Voltage: 13.57 V
    Bin. Bits: 00000
    Hex Value: 0x05C1
    Hex Value: 0x0007
    Speed: 100.8 km/h
    Lateral Accel.: -0.12 m/s^2
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 152
    Mileage: 199686 km
    Time Indication: 0
    Date: 2016.02.13
    Time: 01:14:52
    Freeze Frame:
    Temperature: 8.0°C
    Voltage: 9.34 V
    Bin. Bits: 01000
    Hex Value: 0x0346
    Hex Value: 0x0003
    Speed: 57.6 km/h
    00003 - Control Module
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00111110
    Fault Priority: 1
    Fault Frequency: 8
    Reset counter: 152
    Time Indication: 0
    Freeze Frame:
    Temperature: 9.0°C
    Voltage: 13.44 V
    Bin. Bits: 01000
    Hex Value: 0x0346
    Hex Value: 0x000C
    Speed: -3.6 km/h
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    Mileage: 199827 km
    Time Indication: 0
    Date: 2016.02.14
    Time: 18:21:12
    Freeze Frame:
    Temperature: 15.0°C
    Voltage: 12.54 V
    Bin. Bits: 00000
    Hex Value: 0x044B
    Hex Value: 0x0049
    Speed: 36.0 km/h
    Lateral Accel.: -0.37 m/s^2
    Lisäksi nämä viat:
    Address 01: Engine (J623-CCWA)
    2 Faults Found:
    4330 - Function Restriction due to Faults in Other Modules
    Confirmed - Tested Since Memory Clear
    4709 - No Communications with Cruise Control (Front) Distance Sensor
    Intermittent - Confirmed - Tested Since Memory Clear
    Address 03: ABS Brakes (J104)
    01319 - Control Module for Distance Control (J428)
    004 - No Signal/Communication - Intermittent
    Address 17: Instruments (J285)
    2 Faults Found:
    Address 19: CAN Gateway (J533)
    02001 - Data-Bus Automatic Distance Regulation
    Address 5F: Information Electr. (J794)
    03157 - Functionality limited due to Communications Disruption
    Kiitos etukäteen!
    Jorkki
    Enemmän tuo näyttää siltä että adaptiivisen vakkarin ohjausyksikkö olisi rikki.
      Tai sitten boksin liitin ui vedessä. Riippuen missä fyysisesti sijaitsee. Kuitenkin näyttäisi, että boksiin ei yhteys pysy luotettavana.
      Oliko nuo vikakoodit nollauksen jälkeen uusiutuvia? Tuolla on kuitenkin vähän akkujännitteen kyykkäykseenkin viittaavia koodeja.
        Ohjainlaite ja tutka ovat yksi ja sama osa. Tarkista tutkan liitin ja jos on ehjä niin taitaa olla ohjainlaite vainaa eli koko tutka puskurista vaihtoon. Purkuosana Saksasta kolmisensataa tai uutena pitkälle toista tonnia.
          VCDS ei saa enää yhteyttä koko tutkaan. Sain onneksi aiemmin luettua koodit. Viikonloppuna eri testeriin kiinni, niin katsotaan. Saadaan myös testattua lainatutkalla, josko yhteys palaisi normaaliksi.
            No sitten uskaltaisin pelata korttini hapettuneen liittimen puolesta. Mahdollisesti edennyt ohjaimen sisälle asti.
              Irrotin tutkan. Liittimet oli kunnossa, ei näkyviä hapettumia missään.
                Vika löytyi! Tutkalle menevä virtajohto oli poikki. Apukuskin puolen rengaskotelon alta löytyi kohta.
                  Mikä sen oli rikkonut? Yleensä noita katkenneita johtoja ei ole ollut kuin saranoiden kohdalla.
                    Linkki koko VCDS lukuun linkkinä.
                    Lainaan tätä aihetta pieneen ongelmaani.
                    Elikkäs viikko sitten mittaristo pimeni mystisesti kokonaan ja antoi vaatimattomat 33 sivua vikakoodeja.
                    Auto meni korjaamolle missä todettiin ettei mittaristossa ole vikaa vaan vika on jossain väylässä kun oli alhaalla.
                    Autosta meni mittariston myötä mykäksi myös vilkut ja parkkitutka ja muutama muukin samaan syssyys.
                    Eilen menin autolle kun oli korjaamon pihassa ja piruuttaan testasin kuulopuheiden mukaan muutamia kikkoja millä saisi mittariston eloon.
                    No sehän heräsi ilman mitään toimenpiteitä, mittaristossa palaa nyt vaan luistoneston valo, tpms herja ja ratin kuva.
                    VCDS antaa todella mielenkiintoisia koodeja, mutta itsellä osui silmään tässä Auto Dist. Reg (J428) ohjainlaitteessa yksi mielenkiintoinen juttu.
                    Antaa alla olevia koodeja, mutta sieltä löytyy -3,6kmh mikä mielestäni ei ole kovinkaan looginen?
                    Component: ACC2 H07 0070
                    Coding: 0079B9
                    VCID: 6FBBD217D79BD0DF20D-803A
                    2 Faults Found:
                    Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 317139 km
                    Time Indication: 0
                    Date: 2020.02.18
                    Time: 12:08:26
                    Freeze Frame:
                    Temperature: 27.0°C
                    Voltage: 11.90 V
                    Bin. Bits: 01000
                    Hex Value: 0x044B
                    Hex Value: 0x0013
                    Speed: -3.6 km/h
                    Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 61
                    Mileage: 317139 km
                    Time Indication: 0
                    Date: 2020.02.18
                    Time: 12:08:26
                    Freeze Frame:
                    Temperature: 27.0°C
                    Voltage: 11.90 V
                    Bin. Bits: 01000
                    Hex Value: 0x044B
                    Hex Value: 0x0015
                    Speed: -3.6 km/h
